Please Help
Old Jul 3, 2005 | 11:45 PM
o0haco0o's Avatar
o0haco0o
Cool Please Help
Hello everyone, recently i posted about a "potential" timing chain problem on my`99 Ford Explorer with a 4.0 SOHC. A "rattleing" sound coming from what sounds like somewhere under the car near the transmission. Well i left the problem alone assuming the rattle would get worse and just as i suspected, it has. I have no problems starting the car and no unhealthy sounds occur when i start the car. The rattling is present at idle as well as in gear. Every now and then when im driving i hear a high pitched short squeak sound coming from the front drivers side. I really need to diagnose the problem and i was wondering if these "symtoms" sound like the chain or maybe somethin else. Any feedback would be greatly appreciated. Thanks in advance.
Old Jul 4, 2005 | 12:43 AM
87 XLT's Avatar
87 XLT
Not sure if it's on the SOHC or the OHV, but i've read that the cam sensors can get noisy. Take a listen in the area where the distriutor used to be.
Might help to use a short piece of garden hose like a stethoscope to try & pinpoint the noise.
Old Jul 4, 2005 | 08:41 PM
o0haco0o's Avatar
o0haco0o
Exclamation
Ill check it out. Thanks. Today i was driving and when i press the gas i hear a banging sound. i can feel the bang too. Transmission maybe?
Old Jul 4, 2005 | 09:58 PM
Nand12's Avatar
Nand12
Does the rattle you're experiencing, sound like this? Engine Sound Clip
Old Jul 6, 2005 | 09:10 PM
o0haco0o's Avatar
o0haco0o
no, its not that loud at all. Its a quiet noise but mettallic
Old Jul 6, 2005 | 09:31 PM
Nand12's Avatar
Nand12
The noise could be caused by loose heat shields on your catalytic converter. This is a common problem and easy to fix. You said that you can hear a squeak sometimes coming from the driver's side. It could indicate a faulty idler pulley and/or tensioner. A bad tensioner can cause a rattling noise when it gets worn down enough.
69_Eliminator
Jan 18, 2017 07:44 AM
bigunit54
Nov 25, 2016 06:41 PM
hermannm2
2009 - 2014 F150
May 25, 2016 08:45 PM
handyman43358
Feb 13, 2013 07:16 PM
calzone
1978 - 1996 Big Bronco
23
Aug 30, 2006 11:20 AM
