460 Engine year?
Old Jul 3, 2005 | 12:20 PM
PowerbyFord's Avatar
PowerbyFord
460 Engine year?
I have a question on the year of an engine recently pulled from a 1970 F-250. It is a 429/460, and not originall for the truck. The cast number on the block is C9VE-B, and the heads are C9VE-A. Trying to narrow down a year, so parts can be bought for it. Thanks
Old Jul 3, 2005 | 12:33 PM
cba135's Avatar
cba135
Thats a real good motor. Its a 1969. Those are some of the best 385 series heads.
Old Jul 4, 2005 | 06:50 AM
essjaygee's Avatar
essjaygee
Exclamation What year
This question seems to be asked many times. Here's a little tutorial on Ford numbering.
For a typical part like an engine block it has a basic part number : 6015. You'll see this as part of a whole part number like C9VE-6015-A.
To break it down:
The first position C9VE-6015-A represents the Decade
B=1950-59
C=1960-69
D=1970-79
E=1980-89
F=1990-99
The second position C9VE-6015-A represents the Year of the Decade
The third position C9VE-6015-A represents the Carline
A=Ford
D=Falcon
G=Comet, Montego, Cyclone
J=Marine & Industrial
M=Mercury
O=Fairlane & Torino
S=Thunderbird
T=Ford Truck
V=Lincoln
W=Cougar
Z=Mustang
The fourth position C9VE-6015-A represents the Engineering Group
A=Chassis Group
B=Body Group
E=Engine Group
If the item is a service part, the fourth position then indicates the applicable division as follows:
Z=Ford Division
Y=Lincoln-Mercury
X=Original Ford Muscle Parts Program
M=Ford Motorsport SVO or Ford-Mexico
Then follows the basic part number C9VE-6015-A.
The last character(s) C9VE-6015-A represent the suffix which indicates any revisions. A= original part, B= first revision, etc.
Also, as with most parts, you should be able to find a date code like 5A26
The first position is the year, the second is the month, and the last two are the day it was cast or stamped.
Another bit of interest is where it was made. For blocks, a "C" circled around an "F" indicates the Cleveland Iron Foundry. A "DIF" indicates Dearborn Iron Foundry. A "WF" or "WIF" stand for Windsor Iron Foundry.
Hopes this helps.
burge743
Feb 5, 2020 11:31 AM
psquare7575
Jun 5, 2011 10:03 AM
55F250
Sep 28, 2010 07:04 PM
86rustbucket
Jan 31, 2006 07:15 PM
1977f250
Jan 31, 2006 11:30 AM
