I am having a problem with the brake interlock. The truck will not start or go into gear. I checked the brake light switch and that is working. I then checked the wiring to the interlock solinoid and it is getting voltage when I step on the brake but it seems that the solonoid is dead. Does anyone know if there is a way to override the solonoid. Its almost impossible to get to so I can't tell exactly how it works. I would like to override or remove it for now until I can fix it right. Any ideas?
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
