Yet another Fuel Guage problem from another person
Old Jul 1, 2005 | 02:40 PM
CleanSlate's Avatar
CleanSlate
Question Yet another Fuel Guage problem from another person
I just bout my 94 Explorer,used and abused it may be I fell in love with it the moment I test drove it..well anyways on to the problem.. when the key is either out or just put into the ignition the fuel guage reads between 1/4 to 1/2 a tank which I believe is how much gas is really in it, but when I start it the guage drops to E and doesn't move.. is there a short somewhere? should I try the test with removing the wire from sending unit as many have been advised to do? any help would be great as I'm probably going out of town on the 5th and think it would be a bad idea to have to guess when im getting low while driving down the interstate..
Old Jul 1, 2005 | 03:05 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 1, 2005 | 03:14 PM
Franklin2's Avatar
Franklin2
Yes. That is the only sure way to know if the guage and wiring are good. If I had to guess, your sending unit is probably bad in the tank, but the test will verify this.
Old Jul 1, 2005 | 03:27 PM
CleanSlate's Avatar
CleanSlate
Hmm.. means dropping the tank or figuring out which of the wires running along the chassis is the wire for the sending unit....any idea on the wire colors? sure make things alot faster..
Old Jul 1, 2005 | 08:39 PM
Franklin2's Avatar
Franklin2
Look in the middle of this diagram.
http://www.autozone.com/images/cds/g...3d800ba9ce.gif
You will see the guage runs to the sender on a yellow/white wire. The fuel pump is fed by the pink/black wire.
Old Jul 2, 2005 | 08:57 AM
CleanSlate's Avatar
CleanSlate
so i snip that wire and place it against frame..turn key on, if guage pegs out, the guage and wire is good sending is bad correct?
Old Jul 2, 2005 | 07:54 PM
Franklin2's Avatar
Franklin2
If you can get to it, I would just un-plug the connector from the gas tank. And then shove a piece of scrap wire up into the correct place on the connector and then touch the other end of the scrap wire to a shiny place on the frame. Someone should be in the cab watching the guage, unless you can make the wire stay in the connector and on the frame.
I am not sure if the needle will peg to full when it's grounded, or to empty. Ford changed the way their guages worked in the 1990's, and it's hard to keep track of which way it's supposed to go. But it doesn't matter, as long as it is full scale with the plug unplugged, and then opposite full scale with the wire grounded. That will verify it's working.
Old Jul 2, 2005 | 08:10 PM
CleanSlate's Avatar
CleanSlate
alrighty then, thanks a bunch fer the help..ima try it in the morning
