Brake Ignition Interlock Problem
Old Jul 2, 2005 | 12:15 PM
DansF350's Avatar
DansF350
I am having a problem with the brake interlock. The truck will not start or go into gear. I checked the brake light switch and that is working. I then checked the wiring to the interlock solinoid and it is getting voltage when I step on the brake but it seems that the solonoid is dead. Does anyone know if there is a way to override the solonoid. Its almost impossible to get to so I can't tell exactly how it works. I would like to override or remove it for now until I can fix it right. Any ideas?
My truck is a 2000 F350.
Thanks, Dan
Old Jul 2, 2005 | 03:03 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 2, 2005 | 04:18 PM
DansF350's Avatar
DansF350
I figured it out. I beat the column with my mag light a few times and it works. Something must have been stuck in the ignition.
gary7388
Escape & Escape Hybrid
35
Dec 22, 2014 05:19 AM
ITDave
2004 - 2008 F150
Jul 11, 2012 02:10 AM
nhfire77
Feb 9, 2010 01:46 PM
pavescaper
Apr 1, 2007 08:26 PM
Mark 42
Dec 4, 2006 04:20 PM
