These are all the numbers that are on this engine.
intake has c9ae-9425-b with a large T and a date of 9 H 8
front of block on drivers side has 64 352
rear of block has upside down 40 352
on the pad under the # 5 cylinder is only a stamped 2
under the oilfilter adapter is cast 9 H 1 and under that is M betwee the two is an upside down 36 dif.
the heads have drivers side c8ae-h passenger side c8ae-m
the exhaust manifolds have drivers side c8ae 9431 b and passenger side has c5te 9430 c with the big T to the left.
Whadda ya think?
I've gone over every inch and these are all the number I find.
Greg
Greg, going by the date codes it looks like that is an intact engine. Intake manifold was cast on 8/8/69 and the block on 8/1/69. I would say it’s a late ’69 engine because the ’70 engines used the D0TE exhaust manifolds while earlier ones used the ones you have. What are the numbers on the dizzy? Check the passenger side head again, is it really a “M”? It’s either a 360 or 390, you have to check the stroke to find out.
C8TF-H is a 360 automatic trans. dizzy for '68,'69, no other applications. Your engine sounds complete and unmolested, I bet that's what it is but verify the stroke just to be safe.
