C6 That Won't Quit Leaking
Old Jun 30, 2005 | 04:24 PM
bivens1172's Avatar
bivens1172
My C6 in my 67 Ranger will not stop leaking flluid out of the hole right beside of the fill tube. Is this hole supposed to have a check valve or something to keep the fluid from blowing out?
Old Jul 1, 2005 | 11:48 AM
qman's Avatar
qman
Don't know what that hold is your talking about but mine was leaking from where the shift linkage goes into the trans. There's a small seal in there (shift shaft seal) I had to replace to get the leak to stop. Unfortunately, I had to remove the pan, valve body, and linkage from the inside to replace the dumb seal. If it turns out this is where yours is leaking I can offer a little more detailed advice.
Old Jul 1, 2005 | 01:47 PM
Ford_Six's Avatar
Ford_Six
It sounds like the tranny may be overheating a bit and puking fluid out the vent. You may want to add an inline cooler in front of the radiator and see if that helps.
miottimouse
Oct 17, 2014 07:32 AM
fivefishwish
Mar 20, 2012 05:52 AM
fixingbus
Aug 5, 2007 06:11 AM
djmac
Jun 12, 2007 06:20 AM
shimonmor
Apr 13, 2000 11:48 AM
