fe intakes
Old Jun 29, 2005 | 07:58 PM
fordeverpower's Avatar
fordeverpower
fe intakes
I am looking into swaping an T intake for an S intake. I am wondering if anyone knowns the port size for an S intake or the rpm intake.
Old Jun 30, 2005 | 05:25 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Not quite sure for intake manifold port size on the S code? but I'am sure it would be close to the head port size of 1.93 X 1.34" Now as for the RPM.... One of the other Guys should have that?
Russ
Old Jun 30, 2005 | 05:41 PM
fordeverpower
all i have found says they are 2.20 by 1.14 but that seems a little too big to me!
Old Jun 30, 2005 | 06:36 PM
Bear 45/70's Avatar
Bear 45/70
The "S" intake is the smaller ports for increase intake velocity. Thats why they ended up changing them all to it. Prior to the S intake the ports were 1.34X2.34. As far as I know there is only one FE intake with 2.20 X 1.14, thats the 427 8V and 4V low riser used from '63 to '65.
Old Jun 30, 2005 | 06:59 PM
fordeverpower
somebody needs to write a new improved FORD FE book!
Old Jun 30, 2005 | 07:17 PM
Bear 45/70's Avatar
Bear 45/70
My info comes straight from Ford's Muscle Parts books dated 1969 and 1970.
Old Jun 30, 2005 | 08:10 PM
fordeverpower
bear, I don't have that book so I can't talk about it but ford interchange, ford performance, steve christ all have errors.
Hey can you look up these part numbers?
390 gt intake c6ae-9425-G
428 cj intake c8oe-9425-c
I measured a 2bbl T and got 1.78 by 1.13 +/- .03, but thats all I got for actual measurements right now and I assume my 4bbl T intake to be similar to the 2bbl one.
Old Jun 30, 2005 | 08:44 PM
Bear 45/70's Avatar
Bear 45/70
The book says 2V manifold is 1.16 X 1.75. CJ is 1.24 X 1.94. The standard 390/410/428 is 1.16 X 1.75.
Old Jun 30, 2005 | 08:59 PM
fordeverpower
thanks Bear!
Old Jul 1, 2005 | 05:15 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Thr Muscle Parts book has been scanned and is on this site www.gessford.com if you want to see.
G.
Old Jul 1, 2005 | 05:17 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Forgot to add click on Ford Engine parts then scroll down to the links section. You will see it there. Good luck!
G.
willi
Jun 29, 2015 07:02 AM
Ranger92
May 17, 2011 07:30 PM
fromm
Mar 30, 2010 08:29 PM
302flareside1992
Mar 9, 2010 06:18 PM
1COOKIEMON
Sep 23, 2007 06:37 AM
