intake gasket
Old Mar 23, 2010 | 04:41 PM
fromm's Avatar
fromm
intake gasket
I am looking for opinions on Intake gaskets for a 400. should i goo back with the
valley tin/gasket or just a gasket with no valley pan. I am using an edlebrock intake
Old Mar 24, 2010 | 02:12 PM
beartracks's Avatar
beartracks
Use the pan, it shield the manifold from heat. I wouldn't use any gaskets on the ports unless you have leak problems. Lots of guys use RTV sealant for the end pieces.
Old Mar 26, 2010 | 08:40 PM
vtjvt's Avatar
vtjvt
I second that, just did mine last weekend, get the felpro gasket (metal) and use some RTV instead of the end rubbers, I used the napa gray and it sealed great.
Old Mar 29, 2010 | 10:07 PM
Colo79Ford's Avatar
Colo79Ford
Felpro 1240, great alternative to the valley pan gasket.
Old Mar 30, 2010 | 02:46 AM
johnboy427's Avatar
johnboy427
I second the Fel Pro 1240, turkey pan is a pain.
-John
Old Mar 30, 2010 | 08:29 PM
maskedman's Avatar
maskedman
Use the valley pan gasket.It will help cut the heat in the manifold by keeping the hot splash oil from the lifter valley away from the bottom of the manifold.
chuffer
13
Jul 24, 2017 08:44 PM
77truck460
Jun 18, 2016 08:24 PM
jayinnh
1997 - 2003 F150
Dec 16, 2015 08:00 PM
hivoltj
Nov 5, 2015 10:52 AM
bluemtn95ford
13
Oct 25, 2015 08:13 AM
