How do you get the camshaft out of the block ????
(sorry for the double post but I think I posted in wrong forum up above this one ?)
'69 390 FE , hydraullic lifters
motor still in vehicle
We've removed the timing gears, camshaft retainer plate at front of block....as well as all lifters, distributor, intake (of course)...
And threaded the cam gear bolt back into the cam to get a grip
But we can't pull the cam out - seems like something is holding it in
What did we miss ? maybe something bolted to the rear of the cam ?
Originally Posted by ford390gashog
no, it will ruin the bearings. i would not try to do all that work with the engine in the truck. you should just pull it.if it is a high mileage engine the bearings are going to be shot and you should put in new ones.
You can also pick up the block and shake it until the cam drops out.
Just kiddin'.
Sometimes the stick. Make sure all the lifters are out. If so, either carefully tap it through from the back, or lightly pull it with a slide hammer. Not much choice. There's only one way for it to come out.
-Scouder
Just kiddin'.
-Scouder
on
1 Post
