braking problems
Old Aug 24, 1999 | 01:43 AM
rlblasa's Avatar
rlblasa
braking problems
I recently bought a 87 f-150 for my daughter, I have very limited history on this truck. It had 91000 miles and I replaced the ball joints, steering joints, shocks, brakes including hubs and drums, and new tires. When you brake, more noticeable from a higher speed, it feels like the rear of the truck is hopping or bouncing. This feeling is similar to that of a warped front rotor. Any ideas? It has rear anti lock brakes, could this be the source?
Old Aug 24, 1999 | 07:55 AM
Phillip Guidry's Avatar
Phillip Guidry
braking problems
This got my attention because my 88 F150 does the same thing. I haven't done anything about it yet,but I am going to resurface the drums first and then the rotors and hopefully one are the other will cure it.I really don't think the RABS would cause that so I'll ask you if when you had your brakes done if the mechanic actually put new drums or resurfaced your old ones? If he installed new ones without double checking the factory cut on his brake machine,there is your problem!You would figure a new part out of the box would not need to be "turned",but it just isn't so when it comes to drums and rotors.Also,there is still the possibility that the drum may not have been chucked and squared properly when and if he resurfaced your old drums{it may not be his fault}.
Phillip
Old Aug 24, 1999 | 09:26 AM
bryan_1's Avatar
bryan_1
braking problems
My 89 f150 does the same thing but at slower speeds. Would be interested to find out what the cure is.
Bryan
Old Aug 24, 1999 | 09:46 AM
Dean's Avatar
Dean
braking problems
My '88 does this too! But only after I have applied the parking brake and attempt to drive. Apparently, something is not releasing at the hubs. Thanks for this post. It's good information to check and its nice to know its a relatively common problem.
Old Aug 25, 1999 | 12:12 AM
randy blasa
Guest
Posts: n/a
braking problems
>I did this work myself, and i took them out of the box, they were not checked at the parts store. I will check this out. Thanks
Old Aug 25, 1999 | 03:45 PM
moe's Avatar
moe
braking problems
Yea, mine used to do this and I had my rotors turned and replaced the pads and problem gone.
Moe
85 F150 1500mi. on 302HO
Old Aug 26, 1999 | 03:06 AM
randy blasa
Guest
Posts: n/a
braking problems
removed drums today and returned to the parts store and had them turned. i saw some improvement but the hop is still much noticable.
Old Aug 26, 1999 | 07:17 AM
moe's Avatar
moe
braking problems
Pop's 78
Nov 10, 2010 08:00 AM
HBO1
Sep 9, 2010 10:56 PM
vettdvr
May 28, 2009 05:33 PM
afonda
Dec 26, 2008 01:56 AM
Will_01_GT
1978 - 1996 Big Bronco
Apr 12, 2004 12:32 PM
