I need some help. I have a 1978 F150, with a factory installed 460 (be surprised how people say I installed it). Anyway, when I brake I get a vibration between 25 and 40 mph in the rear of the truck. It feels like the back of the truck is bouncing right of the road. I rebuilt the brakes about 4 years ago. But this started in the past year of so. You name it it was replaced, except for the hard lines and the proportioning valve. I don't feel any vibration in the steering wheel or in the brake pedal. But diffinitely in the seat... and rear of truck. I had the transmission rebuilt, and the rear u-joint was replaced (lost the caps). The guy said the front one was fine. I had a retired Ford mechanic look at it and said there was nothing physically wrong with the brakes. He couldn't explain it. He took it to a frame shop and they couldn't find anything wrong. I have recently replaced the rear wheel cylinders and had the drums turned. I have fairly new magnum gasmatic shocks on it (put on before the brakes). Any ideas?
It sounds like the drums are warped. This can happen by driving with the e-brake slightly on for a short period of time. Usually you can just turn them and take the warp out of them. I would carefully examine the e-brake cables to make sure they are completely releasing.
Yea, still does it after the drums and wheel cylinders were replace. The vibration was there before the transmisson was rebuild. I'll have to look at the E-brake cables. Thanks for the advise.
