1978 - 1996 Big Bronco
Ball joint question
Old Apr 12, 2004 | 08:10 AM
Will_01_GT's Avatar
Will_01_GT
Ball joint question
What does it sound like when your ball joints are shot, I hear/feel a thumping when I brake, some one told me it might be ball joints.
TIA
-Will
Old Apr 12, 2004 | 08:41 AM
jacque_strap's Avatar
jacque_strap
One way to tell, although it may not be the best way, is to set the truck up on a lift, axle stands, whatever you've got, and pull/wiggle one tire. There is supposed to be a little bit of play but not much. If it feels excessive than you've probably got some worn ball joints. Hope this helps some!!
Old Apr 12, 2004 | 11:13 AM
Tidybowlman0's Avatar
Tidybowlman0
could just be a warped brake rotor. Good luck
Old Apr 12, 2004 | 12:04 PM
bronco5.8's Avatar
bronco5.8
To check your ball joints do one wheel at a time, jack up the axle beam so that the wheel is off the ground about 2 inches. Wedge a pry bar or a piece of pipe under the tire and lift the pry bar up and down, have a buddy there to keep an eye out on the ball joints. If there's alot of play then the joints are shot.
If it's not your ball joints, check the radius arm bushings. Worn out bushings will cause the arm to shift when you're braking. Don't rule out a warped rotor as mentioned by Tidybowlman0. Let us know what you find. Good luck.
Warr
Old Apr 12, 2004 | 12:32 PM
broncobob's Avatar
broncobob
I'd go along with bronco5.8 on the radius arm bushing, particularly the passenger side one. On my 94 it was real close to the exhaust, and had a small tin cup heat shield over it. When the heat shield rusted and came loose the bushing melted (or so it looked like), and it started making a clunking noise that was especially noticeable when braking.
bma2001
Feb 19, 2015 05:14 PM
magnet1
2004 - 2008 F150
Jun 30, 2011 09:24 PM
griiz
Aug 11, 2009 03:46 PM
sedrick38
Feb 28, 2009 11:54 PM
Capt.Schenk
Dec 21, 2008 06:45 AM
