Heater Core Issues
About 3 months ago, I replaced my heater core. It was leaking, causing antifreeze to fall in the cab. Not a difficult task. After this fix things seemed just fine. However the other day I was pulling out and gave it a bit more gas than normal, (because of the on coming traffic), any way, once again fluid came into the cab, with that all too familar smell....
So, my question is varied. 1) Is it possible for the heater core to only leak when you punch the gas? What's the best way to determine if this core has a problem? I've alreday replaced the core, as I mentoned, 3 months ago. Replaced the hoses, maybe a month ago.
Thanks, Brian
Thanks, Brian[/QUOT
Remove core from truck. Fill with water, plug one end and with an air compressor set at 15 psi or less, blow into other end. Water will come out at leak, it may be hard to see if leak is small. Food coloring added to water can be used,(rinse throughly if used). I used a small compressor, (one you inflate tires with), and mine had a very small leak in the top.
Check hose clamps on hoses for tightness.
Have used Auto Zone & Advance heater cores; some had leaks out of the box. Last 2 trucks, purchased cores from Ford ($54.00; dealer cost) with no poblems yet.
I've used the worm gear style clamps many times, and find that you have to re-tighten them once in a while to compensate for the stretch.
A better option, grab a set of spring type clamps, as they expand and contract with engine/coolant heat, and stay tight. They are a bit tougher to install in tight places, but it can be done with a bit of patience.
I spent a couple of years working as a motorcycle/sled/atv mechanic, and did an entire summer of R&R on brand new Polaris quad's under warranty due to the use of the worm gear style clamps on the oil cooler from the factory. Guys would head out, heat the machines up for a while, pull over to grab a coffee and a snadwhich, and fire them back up, head off into the mud, and have an oil cooler line blow off. Needless to say, there were very few we got back under recall that were not a complete engine replacement. The update kit included two new oil lines, and spring type hose clamps.
1) Took the new (3month old autozone) Heater core out.
2) Reattached it outside the cab.
3) Fired up the truck, let it run for ~20 minutes, then had my wife floor it a few times.
4) It leaked on the side.
5) Ordered a FORD part........
Thanks for your thought's and suggestions.
B
