Piston Rings
Old Jun 13, 2005 | 01:49 PM
bshackelford711's Avatar
bshackelford711
Piston Rings
I am putting my motor together and i have all of my rings sized to each piston. My only thing is the compression rings. I know how the oil rings go together. but which compression ring goes where. one set of 8 is marked with a green mark and the other with kind of a pink mark. (i have not been smart enough to put a mike to them to check for a difference in thickness, and the thickness of the groove in the piston, but i am at work and the thought just popped into my head that they might be different. I really want to try get those things in this afternoon if all goes well.
This might be stupid to ask but i have never done this before. The gap in the rings. I know that you are supposed to stager them about 1 1/4" from the front of the piston on the compression rings. and about the same except on the back of the piston for the oil rings.
My thing is would it be better is you put that gap 180 degress away from the other gap so that they will be on complete oposite side to each other?
would that hurt anything or cause problems?
i have got how to build big block fords by steve christ and that has been very helpful. This was just a crazy thought that popped into my head to help decrease blowby
Old Jun 13, 2005 | 11:11 PM
bshackelford711
i got my own question taken care off
the rings are different thickness.
so thats that i guess
Old Jun 14, 2005 | 10:33 AM
hiball3985's Avatar
hiball3985
check to see which way the dots are suppose to be, usualy up, you don't want to get them in upside down
Old Jun 14, 2005 | 10:46 AM
bshackelford711
i got
the only question that i have now is
where the gap is placed. I know if all the gaps a inline that it willl cause alot of blowby. and that they are supposed to be about 1 1/4" out of line form each other.
So to reduce even more blowby why not put the at 180 degress away from each other?
or would that cause some bad damage?
Old Jun 14, 2005 | 10:56 AM
hiball3985's Avatar
hiball3985
I've seen people do it different ways, I've done mine 180 on lots of engines with no problem, but I'm sure someone will have a different opinion
Old Jun 14, 2005 | 11:09 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
LOL.. I guess we have all done it different ways..I alway just went 120* out with each ring??
Because if you go 180* that puts the bottom and top ring in the same phase!!
Russ
Old Jun 14, 2005 | 12:00 PM
bshackelford711
so correct me if i am wrong it really does not matter how they go just as long as they are not inline
Old Jun 14, 2005 | 12:26 PM
rusty70f100's Avatar
rusty70f100
I put my compression rings 180 degrees apart, and the oil ring 90 degrees away from each. The compression rings hold the compression, so the opening should be as far apart as possible. However, they should work fine as long as their not lined up.
Old Jun 14, 2005 | 01:12 PM
bshackelford711
THIS IS JUST A THOUGHT...... i KNOW THAT YOU ARE NOT SUPPOSED TO PUT ASSEMBLY LUBE ON THE RINGS BECAUSE THEY WILL NOT SEAT RIGHT. tHE THOUGHT THAT I HAD WAS ABOUT PUTTING ASSEMBLY LUB ON THE CONECTING ROD BUSHING AND PISTON PINS. iS THAT A BAD IDEA OR IS OIL BETTER TO USE?
Old Jun 14, 2005 | 02:17 PM
rusty70f100
I used assembly lube on the wrist pin, and it worked fine. You could probably use either.
Old Jun 14, 2005 | 02:40 PM
hiball3985's Avatar
hiball3985
oil or lube is fine, for years we built engines only using oil, I don't remeber when the first time I saw assembly lube...we never had cam lube either...
Old Jun 21, 2005 | 03:28 PM
bshackelford711
I am questioning this again
On the comp rings i have all of the dots facing up.
but on the oil rings they have no dots. Does it matter which way they go?
Do they have a top and a bottom also?
Old Jun 21, 2005 | 03:45 PM
hiball3985's Avatar
hiball3985
no top or bottom on oil rings
Old Jun 21, 2005 | 03:51 PM
bshackelford711
good then i am good to go with that
now if i can get rid of my thrust bearing question i will be good to go on my short block
I hope
GasserGary
Oct 31, 2016 01:01 AM
Romel77
23
Feb 11, 2016 06:13 AM
breezesboy
May 7, 2015 06:29 AM
mbgts
Jul 12, 2005 09:18 AM
copper_90680
Aerostar
Feb 16, 2004 09:35 PM
