piston ring help needed
Old May 7, 2015 | 06:29 AM
breezesboy's Avatar
breezesboy
So its time to put in rings. I cant find a solid answer on what order to put the rings in. The oil ring I got, but the expander rings....I have one squared ring and onering beveled on the inside with a dot. I have found some that say the dotted bevel goes on top, and some that say its goes second. Any help is appreciated. Also, Im putting this on a mild street build. 400 bored .040 lunati cam aussie heads and aussie pistons... what should my gaps be? From my limited research I should look at gapping my first ring to .018 (.0045*4.04) and my second ring to .022 (.0055*4.04) Is this accurate? and what do I do if my rings gap larger than recommended? lots of questions.
Thanks!
popspuller6.9
Mar 29, 2013 08:15 PM
Royson12
20
Apr 17, 2011 09:45 AM
64F-100
Jan 14, 2009 01:17 PM
KRD
Dec 14, 2007 07:01 AM
Darkstar
Dec 4, 2002 08:02 AM
