Rod Going in PSD?
Old Jun 10, 2005 | 08:06 AM
Douglas DC-9's Avatar
Douglas DC-9
Exclamation Rod Going in PSD?
I have a 1999 Ford F-250 w/ a 7.3 PSD. I bought it used with 92,041 miles on it and she now has 96,176 on her. Last night while idling it started knocking really loud. It almost seems like a rod is going? THe knocking seems to be coming from the "center" of the engine, right in the area of the turbo. THe faster the engine was revved the faster the knocking became. I thought it was bad so I took it to Schmit Ford. While driving it to the dealer the noise seemed to get quieter but you could hear it if you turned off the radio. As I said more then likely a rod is going? Or could it be the turbo?
Thanks,
DC-9
Old Jun 10, 2005 | 08:22 AM
CEP's Avatar
CEP
Might be a bad injector. Do a quick search of this forum and you'll see that a bad injector will sould like the motor is coming apart.
Let us know how it turns out.
Old Jun 10, 2005 | 08:51 AM
Kwikkordead's Avatar
Kwikkordead
If the noise is varying like that it's a bad injector no question. Mechanical damage to an engine, the sound never changes, or only gets steadily louder until BOOM. Coming and going like that-injector. And yes it usually sounds like a very loud rod knock. Sometimes it will get bad enough to make you worry about cracking the block.
Old Jun 10, 2005 | 01:01 PM
1997F-350's Avatar
1997F-350
i looked at your signature and im a little confused. it says 5 speed. do the newer trucks have 5 speed auto's in them ??????????? if not do you mean 6 speed manual? if so it could be your dual mass flywheel too. or the injector just another option too look at!!!
Old Jun 10, 2005 | 01:53 PM
Douglas DC-9
Exclamation
-- It's a 1999 F-250 Ext. Cab, LB, 2wd, 5 speed manual, 7.3 PSD. Just to clairify.
DC-9-32
Old Jun 10, 2005 | 01:55 PM
Kwikkordead
DC-9-32
You should have the solid flywheel then, I think.
Old Jun 10, 2005 | 01:59 PM
Big Red 00 F350's Avatar
Big Red 00 F350
Kwikk or anyone else,
What causes the noise when an injector goes bad??..
Old Jun 10, 2005 | 03:01 PM
Kwikkordead
Instead of a nicely atomized spray pattern there is a big squirt of fuel into the combustion chamber. It all detonates at once.
BANG BANG BANG BANG BANG.
Old Jun 15, 2005 | 10:05 AM
KC0FHM's Avatar
KC0FHM
Ok I've been chasing a problem that is similar to yours combined with hard cold starts on Dale Isley's suggestion I went back and started checking electrical connections and the right rear connector was fried at the glow plug point(#7?), just melted away, however it was way worse on the inside harness both gloplug points were melted away(the plugs are still good) all this melting has compromised the injector connections badly I don't think they could be working at all. I'll get the parts here in a couple days and let you guys know. of all the advice i've gotten on this truck no one has ever suggested anything electrical but with an electrically operated engine you should check all the electrical conections first, then proceed.
Old Jun 15, 2005 | 10:12 AM
KC0FHM's Avatar
KC0FHM
Btw I don't get the really ugly knock until the engine is warm, and empty at speed it's not too bad, when it's cold it actually purrs very smoothly but with no glo plugs it probably isn't detonating until it's warmed up, use an ohmeter to check your glo plugs and be suspicious of any thing out of the ordinary, it's possible to burn up the inner harness with no sign of damage outside the valve cover, if it is injectors you'll be pulling the cover anyway so don't order your parts till you know for sure.
Old Jun 15, 2005 | 02:41 PM
Douglas DC-9
I took her to the dealer and this is what Schmit Ford found...
The knocking is caused by a warn bushing in my dual-mass flywheel. Funny thing is that they haven't worked on it yet (just order parts) and I picked it up a day later with the knocking gone. I've had it almost a week now and there is no knocking. So I don't know what's up, I just don't want to be throwing parts at it. BTW, injectors looked good.
DC-9
Old Jun 15, 2005 | 02:49 PM
KC0FHM's Avatar
KC0FHM
I replaced my dual mass flywheel with a new one about 15K ago we were doing some other work and were going to replace the clutch anyway. prbably got it outa there just in the nic a time
Gustavo33
47
Oct 31, 2016 09:08 PM
Celicadude
Sep 25, 2006 11:50 AM
lynkage
Aug 30, 2004 11:21 PM
triaxle
Modular V10 (6.8l)
15
Apr 11, 2004 12:31 PM
Bosaw
May 8, 2003 08:57 PM
