Difference between 2wd headers and 4wd headers?
Old Jun 7, 2005 | 11:00 PM
fling's Avatar
fling
Right now i am 2wd no power steering 68: F250 and i want to buy a new set of headers. My problem is, later on i might possibly convert to 4wd as well as power steering. What is the interferance when using a 2wd headers on a 4wd truck? thanks -Phill
Old Jun 8, 2005 | 02:31 AM
Ford_Six's Avatar
Ford_Six
Usually, 2wd headers are longer and go lower than 4x4 headers, so they interfere with the transfer case and the driveshaft.
Old Jun 8, 2005 | 09:52 PM
rebocardo's Avatar
rebocardo
The difference between the 2wd and 4wd on your truck is the location of the steering components and steering box (basically behind the axle on a 2wd and in front of the axle on a 4wd). Just get the headers that please you since it is quite the project to switch from 2wd to 4wd, you are not using them over, and unless you have a complete donor (which includes the rear sump pan )it is just easier and cheaper to buy another truck (if you can find the 4x4).
Justin73supercamper
Oct 4, 2016 03:42 PM
Jklnhyd
Jun 5, 2016 03:15 PM
Nicktitan
Mar 2, 2015 01:55 PM
MavSprint
13
Nov 13, 2012 02:36 PM
bigtymer77
Mar 20, 2007 09:59 AM
