Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
New Floors
Old Jun 9, 2005 | 12:02 PM
rlh's Avatar
rlh
What's special about the grout? I guess its Leno's Gold option.
I wonder if there's another grout that could be used . . .
I got a good laugh yesterday on garage door hardware for a sliding bifold type set up for a 12 wide, 10 high door, $3200, just the hardware like tracks rollers, hinges pulls etc. They didn't think it was funny when I asked them if Vanna White came with it.
Old Jun 9, 2005 | 03:16 PM
fatfenders56's Avatar
fatfenders56
Unhappy
I felt the same way when I figured this floor, about $6700.00 I only spent 7k for the building. Guess I'm back to painting the floor
Old Jun 9, 2005 | 08:43 PM
sc4x4's Avatar
sc4x4
How about commercial floor tile? It 1/8 in thick, comes in black and white, the pattern goes all the way through so it is durable and it sells for around $1.00 sq ft or less. You can glue it straight down to the concrete and it should hold up for a long time. It should be far more durable than paint or epoxy coatings.
Old Jun 10, 2005 | 07:30 PM
bpez's Avatar
bpez
Anyone know how the commercial tile would hold up in an unheated garage in the NE? Brittle?
Old Jun 11, 2005 | 06:05 AM
Greg 79 f150's Avatar
Greg 79 f150
Not too well, the temperature extremes will weaken the adhesion bond.
Old Jun 13, 2005 | 06:50 AM
Ian F's Avatar
Ian F
Yeah... as Torque posted, this has been a common subject over the past year or so since I found this forum... From what I've researched, there isn't really an affordable way to finish a garage floor and have it hold up.
Epoxy paint from the home centers isn't terribly expensive, but the prep to make it adhere well is not easy or cheap. By the time you're done, you'll probably be looking at $1000 or close to it. The semi-hidden cost of the prep is the real drawback to epoxy... and it's worse with an older, greasy floor.
Tile is an attractive floor, but as you have seen - not cheap and you would need to make sure to use an extreme environment adhesive. Plus, a lot of the prep required for epoxy would be needed for tile adhesive.
Plastic tile is the option I've been looking at. While not cheap, the prep is minimal and there is the option of taking it with you should you move. Plastic tile can also be one of the easiest options if you have hydrostatic water issues.
Old Jun 15, 2005 | 07:40 PM
mzimmers's Avatar
mzimmers
Tile...not cheap? The commercial tile I'm thinking of can be had for about $1/square foot at Home Despot. If one is concerned about the adhesion, I'm sure that the bewildering array of 3M adhesives would include something suitable.
It's not as cheap as paint up front, but should be lower maintenance and possibly less expensive over the long haul. My main concern would be how to get the damn things straight, so it doesn't look really dorky.
Old Jun 15, 2005 | 08:06 PM
2Fords1Jeep's Avatar
2Fords1Jeep
Benjamin Moore makes a commercial grade Epoxy based floor paint that is awesome. It is not a two part paint but it works very well. Acid etching the floor is a must prior to painting. The paint doesn't lift or chip.
I would stick to a light color such as gray, not the speckle or multi-colored paints I've seen at Homey Cheapo. Can you imagine trying to find a small part that has dropped on that kind of floor?
Old Jun 16, 2005 | 09:13 AM
fatfenders56
I have heard good things about the Benjamin Moore stuff before, Does anyone know if it's available in black?
Old Jun 16, 2005 | 09:47 AM
2000F-150XLT's Avatar
2000F-150XLT
As sc4X4 hinted at in his post, if you decide to get tile, make sure that the color goes all the way through. After all this is a garage and the floor will get nicked and scraped, if the color goes all the way through, these nicks and scapres will be much less noticble.
Most of the true "tiles" have color that goes all the way through, it's when you start using the lino faux tiles that you have a problem. Trust me, I have to re-do the floor in the rec room becuase the lino has gotton cut up so bad. Just my $.02.
Old Jun 16, 2005 | 11:54 AM
2Fords1Jeep
Fatfenders
The product is Epoxyester by Benjamin Moore. Their product number is M25. Stock ready mixed colors include Platinum grey and Light grey which is the darker of the two. Black or Charcoal can be mixed for you as a custom color.
56fordguy
30
Jan 10, 2012 11:10 AM
rockher_man
Mar 7, 2008 06:52 AM
56f100pickup
Jan 21, 2007 11:50 AM
keith56_cruz_cab
40
Jun 13, 2005 07:49 AM
Wicked 56
Jun 10, 2003 05:20 PM
