Wrong hitch from trailer salesman?
Old Jun 7, 2005 | 01:40 PM
mrc59's Avatar
mrc59
I bought a dump trailer with a 10K GVWR, for an '04 F350 with factory 12.5K receiver.
Sales reccommends a HD 10K drop hitch/ball.
Finally loaded the trailer up (with cement sidewalk). It was not overweight, but was close: 9600# or so. Rode awful. Turns out, max is 6000# without a WD hitch. So, why would sales not reccommend a WD hitch from the beginning? Should I upgrade to take max weight (e.g., over 6K?)
Old Jun 7, 2005 | 02:17 PM
Steina's Avatar
Steina
CO River Rat
How bad did the rear end sag? Depending on how you loaded the trailer, you could have had almost a ton of deadweight on the ball. What type of brakes does the trailer have? If it's surge, not all WD systems are compatible with this.
Steve
Old Jun 7, 2005 | 03:21 PM
mrc59's Avatar
mrc59
The backend of the truck didn't sag really, and the trailer was well-balanced. Problem was in the handling and feel of the trip. It felt "squishy". Way more than I thought it would behind a 350.
Also wondering if I'm legal over 6K pounds of trailer without a LD hitch?
Thanks!
The Brimar has electric brakes. Seem quite adequate too.
Old Jun 7, 2005 | 07:20 PM
Steina's Avatar
Steina
CO River Rat
With electric brakes you can use just about any WD system you want. I sure would add it; if you have/cause an accident while towing that trailer and you're way over the deadweight rating, you could open up a big Pandora's Box of legal problems......
Steve
Old Jun 7, 2005 | 07:31 PM
SoCalDesertRider's Avatar
SoCalDesertRider
If the trailer was loaded to 9600 lbs and the back of the truck didn't sag hardly, I'd say the trailer was loaded with too little weight on the tongue, which contributed to your squirelly ride. A 10K trailer needs 1000-1500 lbs on the hitch. With that much tongue weight, you'll likely need a weight distributing hitch.
If your hitch is only rated to 6K with a regular weight carrying hitch, you need the weight distrubiting hitch for it.
Old Jun 8, 2005 | 05:57 AM
jowilker's Avatar
jowilker
WD hitches are generally mostly used with camper trailers, and generally not used with construction trailers. Const. trailers can be loaded and unloaded quickly so the weight changes. A camper weight stays fairly constant.
As posted before, make sure your tires are inflated to the max when using your trailer.
John
Old Jun 8, 2005 | 08:09 PM
04superduty's Avatar
04superduty
my work has a bri-mar dump trailer which we cant use a WD hitch on due to the hydraulic box on the tongue.
we also have a leaf inclosure and vacuum that bolts onto the top of the trailer for leaf clean ups in the fall. the tongue weight without anything in the trailer is over 1000 lbs. any truck that pulls it does squat alittle but still eaisly handles the weight.
just make sure to use a solid hitch and a good ball.
Old Jun 9, 2005 | 07:01 AM
mrc59's Avatar
mrc59
All good points. Thanks for the help.
Old Jun 10, 2005 | 12:55 AM
mlb4966's Avatar
mlb4966
I agree with SoCal that the squimish ride was probley due to not enough weight on the tongue. It like loading 200 24-foot 1x6's on a 16 foot trailer. Boy did that get squirrly. Ah leson learned.
wrvond
All Things Towing
Jan 26, 2017 05:59 AM
TRHOD121
Oct 10, 2014 08:39 AM
MudhenGIB
All Things Towing
Feb 24, 2011 10:01 PM
japar
All Things Towing
Jun 6, 2006 08:56 PM
mericanwit
2004 - 2008 F150
Jun 13, 2005 01:39 PM
