The famous clunk I guess
Well, I posted earlier about the clunk, or slop in the drivetrain when taking off from a dead stop. Took it to the stealership for an oil change and asked them about it. He said they checked it out and thought the carrier bearing was a little loose. Not too bad. For 160 bucks they could replace it.
I think I will try the grease on the slip joint first. Then if necessary I can change the carrier bearing.
How big a job is this? The greasing of the slip joint doesn't sound too hard, what about the carrier bearing if necessary?
Thanks
Frank
Thanks
Frank
In order to change the carrier bearing the rear differential will for the most part have to be fully dissassembled, aside from the pinion shaft. The carrier bearings are installed on the left and right of the ring gear carrier and the axleshafts pass through these. You'll have to remove your axleshafts to get the carrier out. The carrier bearings usually have to be pulled off via a bearing splitter and have to be pressed back on. The carrier bearings have to be preloaded, and they also establish the mesh pattern of the ring and pinion. This part takes some time and must be set up correctly to prevent noise and premature wear.
Sometimes called a "swing bearing" the carrier bearing is bolted to the frame and is attached to the rear portion of the front driveline. To grease the splines: chock the tires, put tranny in neutral, disconnect one side of the rubber boot from the driveline connection, remove the carrier bearing and move the carrier bearing out enough to separate the drivelines. Install the grease liberally (Teflon).
HINT: Drill and tap yoke for grease fitting if you have the capabilities...
Then reinstall.
Then reinstall.
Excursion clunk in transmission
I too have a clunk when i press the gas from a dead stop. Kinda a "thud" but it only happens in forward gear and not reverse. I had it at the dealership today for oil changes and they acknowledged a SMALL clunk could be caused by the sealed slip-joint but after driving my X around they tell me the clunbk it too prominant to be the slip-joint. They went on to tell me it must be some type of bushing (forgot the name of it already) internal to the tranny housing that holds the driveshaft inline. The X has been used to tow alot but never over weight. Any thoughts???
01 Excursion
V10, 4X4, 4.30 Gearing, 48K miles
01 Excursion
I also have been noticing a clunking noise coming from the rear of the truck. I haven't has time to investigate thoroghly, but at first I was blaming the the traction bars. The truck only has 5000 kms on it, so I'm wondering if part of the traction bar assembly/rear lift needs to be re-torqued. If it had more kms on it I would be leaning heavily toward a u-joint problem. I get one clunk when decelerating at low speed to a stop, and another on take off. I already checked the box for something sliding around, because thats what it seems like.
Update on my tranny issue. I'm not 100%v sure of what the dealership was talking about in the tranny that could cause the clunk. I took a 500 mile trip this week and I lost Second gear and the torque convertor isn't locking into overdrive anymore, so it is overheating badly. Pretty much, the good ole' 4R100 tranny died. Instead of tearing it down and having it rebuilt, Im having a PROformance tranny unit installed. I'm not tranny intelligent and I'm visiting family away from my tools even if I wanted to try it. The PROformance is suppose to be tougher than Ford original but I've always used Motorcraft parts, so this is a first for me using aftermarket, especially something as big as the tranny. I'll let ya'll know how the install goes when it is done and how well the new tranny works.
OK. I ended up swapping up the tranny for a rebuilt for PROfessional Transmissions. Seems rock solid so far, but only about 750 miles on it at this point. ANyone out there running a V10, 4X4, with 4.30 gears? If so let me know what your shift points are...ie 1st into 2nd at 30mph and 2500rpm and such. I am wondering if its just a different tranny or maybe my old one didnt work for a long time. I run 2500RPM at 70MPH and 2000RPM at 55MPH in my X's configuration.
Originally Posted by missouguy
Well, I took it to a driveline shop and had the guy take a ride with me. He said not to sweat it. He said if I lube the splines it will go away. So I guess that is what I'll do.
Frank
Frank
BigRedTank,
Not ignoring you (I have the 4.30 gearing), but I have a manual tranny. Maybe someone will come along here shortly and help you out.
