Sponsored by: Real Truck
Cruise Control Not Working
Old Jun 3, 2005 | 09:02 PM
marsee's Avatar
marsee
Hey guys,
I need some help here before I go to the shop. I've got an '01 F350 Lariat V10 4x4 CrewCab. The Cruise Control has hardly been used and I just found out obviously when I came to use it that nothing happens when I press the On button no light in the display nothing!
I thought it might just be a fuse, however apparently there's no straight link of a fuse to the cruise control that would make it malfunction.
Has anyone had similar problems with this vehicle and year. Any and all feedback would be very much appreciated.
Cheers,
Surrey, British Columbia
Canada
Old Jun 3, 2005 | 10:54 PM
KenReb's Avatar
KenReb
On my '01 F-250 the cruise light does not come on until the cruise is set. Goes out when disengaged.
Old Jun 3, 2005 | 11:17 PM
99bajakid's Avatar
99bajakid
you cant just press the 'on' button, you need to push on and some other button that i cant remember now.. its the middle button on the right side. i think its a 'resume' button.. ?
Old Jun 4, 2005 | 06:24 AM
Kraut's Avatar
Kraut
On-->Set
I think... THEN the little green speedo lights up on the dash...
That's what my '03 does anyway...
Old Jun 6, 2005 | 02:12 PM
Munkey's Avatar
Munkey
Marsee,
First off, WELCOME TO FTE!!
Kraut is correct in the steps needed to activate the cruise control.
In my case, my cruise control was acting very wonky. Sometimes it would activate, then shut off. Other times wouldn't come on at all. It took a small fire under the hood to discover the reason why my cruise control wasn't working. Turned out to be the Cruise Control switch at the end of the master cylinder. The fitting that the switch connects to started leaking, and shorted out the switch. Easy fix for a fustrating and potentally dangerous problem!
Here's a few sources:
Post: Leaking Sensor
Post: F-450 Cruise Not Working
Post: Truck Stuck In Park
(Problem I had which led to finding the fried switch, fire on page 2.)
Gallery: Tech Pictures
(3rd & 2nd to the last pictures show the switch.)
davebapst
Jul 12, 2006 09:51 AM
jason86
1997 - 2003 F150
Jun 14, 2006 02:59 PM
douggant
Jan 9, 2004 07:36 PM
MikerMan
Electrical Systems/Wiring
Sep 19, 2002 06:24 PM
BB2
Aerostar
Jun 12, 2001 06:35 PM
