Cruise control
Old Jan 8, 2004 | 10:11 PM
douggant's Avatar
douggant
Cruise control
Got an F250 XLT, 4X4, 7.5L engine. Just bought it used. In great shape, but cruise control is not functioning. Fuse is OK. Any suggestions for troubleshooting?
Old Jan 8, 2004 | 10:30 PM
Jimbeaux's Avatar
Jimbeaux
I cleaned the tracks under the steering wheel when I pulled it to fix another problem in the column and the cruise control started working.
Old Jan 8, 2004 | 10:37 PM
Slade901's Avatar
Slade901
Probably the cruise control vacuum hose is loose or cracked. Try tracing the cruise control hose to the servo.
Old Jan 9, 2004 | 09:18 AM
tsheriff's Avatar
tsheriff
Do your reverse lights work? If not then the MLPS switch on the trany is bad. For some reason they work off the same sensor.
Old Jan 9, 2004 | 09:36 AM
bobcf's Avatar
bobcf
http://www.members.shaw.ca/k2pilot/C...iagnostics.doc
Old Jan 9, 2004 | 07:36 PM
donnor's Avatar
donnor
need more info
F-Series cruise control changed with the 1993 model year from the earlier vacuum modulated style to an electronic / electrical servo. Some of the controls interchange, but the majority of the system was new.
dn.
Orlie
Feb 27, 2023 09:32 AM
ItsAFord55
1997 - 2003 F150
Mar 2, 2014 12:11 PM
mikefox670
Aftermarket Products
Oct 16, 2004 11:41 AM
4x4x4x4
Jan 13, 2003 10:35 PM
