Idle Speed
Old Jan 19, 2013 | 02:08 PM
brandon.edwards's Avatar
brandon.edwards
Idle Speed
Does anyone see, or forsee a problem if i have my truck set to idle in the 900's range?
Old Jan 19, 2013 | 04:47 PM
dannyboy950's Avatar
dannyboy950
As far as I know unless your a programmer and reprogram the PCM ain't gonna happen not pemenantly anyways. Cruise control can be used to boost it up a little. but once ya touch the throttle or braes it will kick out and pcm takes back over.
WE had a few trucks with PTO driven hydraulic pumps, needed 1100 rpm to work, used the cruise to do it.
Old Jan 19, 2013 | 05:21 PM
mhoefer's Avatar
mhoefer
Do you mean a high idle switch, we do it all the time. As for a regular idle why?
Old Jan 19, 2013 | 05:44 PM
69cj's Avatar
69cj
High idle mod equals 1200 rpm in neutral. Standard idle is app. 650 in gear or neutral.
Joezilla
Sep 26, 2019 03:04 PM
kinchaser
Jul 24, 2003 07:47 PM
69_bronco
May 13, 2003 07:37 AM
Glenn0184
1983 - 2012 Ranger & B-Series
Apr 22, 2002 12:24 AM
waterspots6
Oct 7, 2000 06:13 PM
