NP 435
Old Jan 25, 2000 | 02:45 PM
Rob400's Avatar
Rob400
NP 435
What is the ratio of first gear in the NP 435 that was in Ford pickups? I want to swap one for my 5spd because of its high first (3.9). I know the 435 has no OD, but I didn't get a truck for good MPG. How long is it? I need one for a 4X4 with small block bellhousing. Can they be used with a hydraulic clutch? Are there any other standards that are as strong as the 435?
Thanks
Rob
Old Jan 26, 2000 | 01:13 PM
carl_1's Avatar
carl_1
NP 435
1st gear for the ford np435 is listed as 6.69.
I am in the process of installing a 435 in my 93 f150 4x4. The best way to do this swap would be to find a truck like yours with the trans you want and take all the necessary parts.
I went with a manual clutch linkage set-up.
Carl
Old Jan 26, 2000 | 04:08 PM
Rob400's Avatar
Rob400
NP 435
I would like to know more about your swap. I really want to do it, and the sooner the better, I need a new clutch. What was the tranny the 93 had? Are you using the original T-Case, or one that came with the 435? If the original, did you need an adapter plate? I'd like to find a 205 to go with the 435. Did you need new driveshafts? How much work/fabrication is involved in the clutch linkage? Any info is greatly appreciated.
Rob
robwaz316(No Email Addresses In Posts!)
Old Jan 26, 2000 | 04:32 PM
fshoffner's Avatar
fshoffner
NP 435
Samsn4
Jul 23, 2023 12:41 PM
Scifi266
Sep 22, 2010 08:57 PM
big block power
Nov 14, 2002 06:36 AM
aunchman
Aug 5, 2002 04:55 PM
72_F_100
Mar 18, 2002 04:15 PM
