p/s pump noise
Old Jan 4, 2000 | 10:32 AM
Jim P.
Guest
Posts: n/a
p/s pump noise
I have a 94 4x4 ext cab long bed with the factory towing pkg. I bought the truck used 1.5 yrs ago and have not had any problems. The powersteering pump has always made a noise that sounds like a hydraulic cylinder actuating when I turn the wheels.I have no leaks and the fluid level is good.I haven't had any problems with the pump at all but was just curious about the noise. There is not any noise when the wheels are not being turned. I read an article once about there being a possibility of having a heavy duty pump that is just louder. Is this the case and how could I verify the pump model. Thanks in advance
Old Jan 5, 2000 | 12:09 AM
Steve's Avatar
Steve
p/s pump noise
Jim,
There was an earlier post stating that you could reduce the noise by raising your front end off the ground and with your engine not running, remove the p/s reservoir lid and crank the wheels back and forth.
Does anyone recall this? I have the same problem but have not had time to try this method.
Steve
Old Jan 5, 2000 | 12:58 AM
Boss_358's Avatar
Boss_358
p/s pump noise
More than likely there is nothing wrong with your power steering. As far as I know with the style pump your engine has they always make some noise.
Old Jan 5, 2000 | 07:11 AM
slik's Avatar
slik
p/s pump noise
Raising the wheels off the ground and removing the lid (keep motor off) and moving your steering wheel side to side (12-15 times) will eliminate air from your lines which can cause noise. But, from what I read, the Ford truck pumps tend to be noisy. You may also get an increase in noise as your fluid heats up and installing a PS cooler can help with that.
Just my 2 cents,
Slik
Old Jan 6, 2000 | 10:45 PM
mholota's Avatar
mholota
p/s pump noise
I have never known a ford like this not to moan and groan in its power steering.
Make sure the fluid level is up and as long as there is no pull on the steering don't worry.
Old Jan 24, 2000 | 04:31 PM
Ron's Avatar
Ron
p/s pump noise
Old Jan 26, 2000 | 12:14 PM
SPLabar's Avatar
SPLabar
p/s pump noise
I have one just like yours, same noise too. They are all like that. Nothing works I've tried it all. Ford pumps are just noisy. I was once contemplating replacing it with an older style GM pump that I know is quiet.
Old Jan 26, 2000 | 05:41 PM
slikness's Avatar
slikness
p/s pump noise
I put the GM pump with remote resevoir on mine and it seems to be quieter. Works great; but I also put on a GM 100 amp altenator, and the whining sounds like a turbo. Once the engine is above 1000 rpm the whining drives me crazy. At least I can drown it out with the stereo!!
'82 F150 w/351W (orig 300 I6)
Slik
