NP435 2wd? Can a transfer case mount to it?
Old 07-27-2002, 10:15 AM
aunchman's Avatar
aunchman
aunchman is offline
Ok, am in the middle of my project 2x4 to 4x4, everythings going good!! I am comparing axle codes and trans code with my donor truck. I noticed I have the same transmission in my 2wd as the 4wd, which is a NP435. My question is will the transfer case bolt up to any NP435. Or is there a difference between the NP435 2wd and NP435 4wd?
Old 07-27-2002, 03:40 PM
ecarter50's Avatar
ecarter50
ecarter50 is offline
the output shaft and tailhousings are different.
Old 07-27-2002, 10:00 PM
aunchman's Avatar
aunchman
aunchman is offline
So the transfer case won't bolt up after removing the tail housing? Sounds like it would be easier just to use the transmission the transfer case is mounted to. The change over is going great! What kinda of transmssion jack is the best to use when taking out and intalling the transmission wit hthe transfer case does the cradle that attaches to the floor jack really work well?
Thanks again,
Chris
Old 08-05-2002, 04:27 PM
redneckdieselmechanic's Avatar
redneckdieselmechanic is offline
the best kind is somethin with a adjustable jack pad and chains. Also big casters that roll over dirt on the floor.
Old 08-05-2002, 04:55 PM
j-swizzle
01-21-2015 10:54 PM
MNTBUGGY
04-03-2012 12:56 PM
401477534
08-13-2011 10:06 AM
Scifi266
09-22-2010 08:57 PM
flyhound
12-15-2003 12:21 AM
Quick Reply: NP435 2wd? Can a transfer case mount to it?
