460 w/4 bbl "flooding"
Old May 30, 2005 | 06:57 PM
Rmvr53's Avatar
Rmvr53
well, after 130 pages of arcives I robably missed the same topic but here goes.
I have an 83 "C" class RV on E350 chassis and 460 4 bbl. Not sure of the carb but I think is a 4180 - only adjusting screws are the 2 on the front and small caps over the float adjustments on front/rear bowls.
Heres the problem - at idle it loads up like its flooded. After driving for just a few miles, its smokin out the pipe (black) like its still flooded. The auto choke appears to be opening up ok. What do I check next or ?? HELP!! as I need the unit this coming weekind..
thanks
Bill
Old May 31, 2005 | 11:04 PM
LxMan1's Avatar
LxMan1
Sounds like a stuck needle and seat. Possibly a small piece of debris has gotten into one of them. If possible, look down into the carb while idleing and see if gas is dripping into the front or rear barrels. If so, then the needle and seats must be checked. Could also have a pin hole in a float causing it to not float properly.
Old Jun 1, 2005 | 08:45 AM
Putt's Avatar
Putt
Could also be the bad power valve problem, I don't think the 4180 series had valve blow-out protection from the factory.
Old Jun 8, 2005 | 02:36 PM
rlh's Avatar
rlh
Sticky/saturated floats?
Old Jun 9, 2005 | 12:30 AM
termyt00's Avatar
termyt00
yup all of the above... but personally if it were my RV, I'd switch to a Edelbrock/ Carter, why ...well they're just better! that Holley will always require a rebuild if you let it sit too long...trust me i've done it to many times to count....
Old Jul 5, 2005 | 09:09 AM
wally2117's Avatar
wally2117
Had the same trouble with mine last week.
A debris in the needle of the back bowl. fuel saturated the carb and... fill the exhaust.
caboom! exhaust is shut...
Old Jul 5, 2005 | 11:41 PM
Rmvr53's Avatar
Rmvr53
Fixed It!!
rebuilt the beast...found the "Idle enrichment valve" to be able to spin in its housing - as in shot - nice "smooth" (burble) idle now.
thanks for the direction/guideance
Bill
69'er
Jan 25, 2017 06:18 PM
brian eiland
43
Mar 3, 2016 07:06 PM
78ferd
May 9, 2015 03:03 PM
mb1096
Oct 7, 2011 10:49 AM
79GreenMonster
1978 - 1996 Big Bronco
Feb 16, 2002 12:33 AM
