floody 2150
Old May 7, 2015 | 09:07 PM
78ferd's Avatar
78ferd
floody 2150
Hi guys. Ive got a 78 f150 2x4 351m stock through and through. Been chasing a no start issue for a month now. Started with an ignition issue and now im stuck with my carb flooding my intake out ive rebuilt the carb and set the float and it still floods the left side of the intake out which im guessing is the reason I cant get it to fire. Its the 2bbl 2150 my question being what would cause it to flood out like this?
Old May 7, 2015 | 11:04 PM
Jrgunn5150's Avatar
Jrgunn5150
Well if you had an ignition issue, I'm guessing you had some backfiring? Flooding leads me to think powervalve.
Old May 8, 2015 | 08:41 AM
78ferd's Avatar
78ferd
Yeah it had backfired and I thought the same thing so I rebuilt the carb powervalve and all and its still flooding out the intake lol
Old May 8, 2015 | 10:17 AM
Jrgunn5150's Avatar
Jrgunn5150
Is the float installed correctly then?
Old May 8, 2015 | 11:07 AM
Jchet729's Avatar
Jchet729
Float was the first thing that came to mind to me... pull it off and double check maybe...
Old May 8, 2015 | 05:13 PM
dentsides's Avatar
dentsides
Did you replace the base gasket under the carb?
Old May 8, 2015 | 05:39 PM
Jdeshler's Avatar
Jdeshler
Make sure you put that little metal/rubber oring under the needle seat as well!
If there is any trash at all in the venturi it will cause a steady drip and flooding (at idle)
Iv generally learned that if you don't soak these things overnight, scrub every piece with a toothbrush and blast each cranny with 100psi the rebuild will be in vain
Old May 9, 2015 | 01:43 PM
78ferd's Avatar
78ferd
Ill recheck the float and needle seat when I pull the carb today. It was doing the same thing before the rebuild which is why k did it ill rip her apart scrub and soak it overnight and blow it out maybe theirs a speck of crap stuck in there
Old May 9, 2015 | 03:03 PM
78ferd's Avatar
78ferd
I did replace the base gasket dentsides
Lower Deeezy
May 20, 2009 08:47 AM
mudslingur
Dec 31, 2007 08:49 PM
