Koer Code 213
Old May 21, 2005 | 07:47 PM
pikiluvi's Avatar
pikiluvi
Koer Code 213
It's a 1994 F-15 with a 300 EFI auto;
It give me code 213 spout spark circuit open. Has anybody this problem before? Where do I need to look for this problem?
I will appreciated any help. Thanks
Old May 21, 2005 | 08:04 PM
95X15's Avatar
95X15
Look for a two wire pigtail by the driver's fender firewall - It should have a black jumper installed. It is either loose, corroded or the jumper is missing. It is used to set the base timing by disabling the computer control of timing during manual setting of timing with a timing light. It should have a P (pink ) wire on both sides of the connector; all the jumper does is connect the two wires. You can just jumper the connector but it would be best to get a replacement so it doesn't fall out.
Old May 21, 2005 | 08:25 PM
pikiluvi's Avatar
pikiluvi
Thanks I find it; but it's one wire only; Thakns againg!
Paul52097
Oct 20, 2013 11:37 AM
dragonsfyre
Jul 20, 2013 02:39 AM
Suhaj213
1997 - 2003 F150
Jun 7, 2013 11:52 PM
suthrnslew
Sep 29, 2011 09:47 AM
CAlex
May 3, 2006 12:28 PM
