Code 213: Spout Circuit Open
Old Sep 28, 2011 | 04:53 PM
suthrnslew's Avatar
suthrnslew
91 F150, 302.
I went to drive the truck this morning and it almost couldn't pull itself up some hills. Felt like a bad miss or timing, the truck was shaking under a load.
Pulled codes and got the Spout Circuit Open. The plastic jumper is in place on the connector. I took it off, it looked ok and then reseated it.
It had been running fine before today, I don't know what to try next.
I did a search and found a thread on code 213 but didn't seem like his problem found an answer.
Old Sep 28, 2011 | 07:27 PM
rla2005's Avatar
rla2005
You need to verify that SPOUT plug still has continuity. It is rare for them to go bad, the typical culprit is a corroded connector.
After that it is time to meter the SPOUT circuit. Use this as a reference:
Courtesy of FordFuelInjection.com
Old Sep 29, 2011 | 09:47 AM
suthrnslew's Avatar
suthrnslew
Thanks for the reply, I'll give that a try with a multi tester.
I'm not too swift tracing down electrical problems.
I hope it's just corrosion at a connector.
That's probably too much to expect.
PagosaFord
Mar 4, 2018 02:35 PM
p1fried
Jun 10, 2009 08:18 AM
hillie16
Jun 13, 2008 04:43 AM
Montana Bob
Dec 7, 2004 08:10 AM
cougar86
Feb 3, 2004 10:56 PM
