Transmission swap
Old May 18, 2005 | 01:07 PM
rs2600's Avatar
rs2600
Transmission swap
What issues do I run into by swapping my T18 for a Top loader or a T10. I have a 65 F100 with 352/T18.
Thanks,
Mat
Old May 18, 2005 | 07:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 18, 2005 | 09:12 PM
Putt's Avatar
Putt
You will need to shorten your driveline, adapt a shifter to your liking, and depending on the year of the T10 or Toploader, you may need to change the bellhousing/trans bolt holes. The tranny mount is different also and it is further back than the T18. The crossmamber will slide back in the frame and then drill new holes to bolt it in place.
I have a Toploader in my '66, before that I had a T10.
Old May 19, 2005 | 12:45 AM
rs2600's Avatar
rs2600
Trans swap
Thanks, just about what I figured. Which one is the best, T10 or toploader?
Mat
Old May 19, 2005 | 09:23 AM
Putt's Avatar
Putt
The Toploader is a stronger tranny, but as long as you don't abuse it the T10 is very durable AND it has new parts available. You can even get an aluminum case T10 brand new, so it depends on usage. I used the T10 for about 100K miles and a lot of that was towing a horse trailer(about 8-9K lbs. loaded). It was in need of replacement after that!! Neither of those tranny's is designed for heavy load(weight), long term pulling like I did, so in a way I guess you could say it lasted very well.
There are pictures in my gallery of my trans setup, let me know if you need some detail shots of mounts, etc. and I'll see what I can get.
Old May 19, 2005 | 11:49 AM
rs2600's Avatar
rs2600
Is there any difference in boltpattern to the bellhousing bewtween a Ford and a Chevy T10? Any difference in splines?
Mat
Old May 19, 2005 | 09:12 PM
Putt's Avatar
Putt
Yes there is, in both places. The spline is probably adaptable(just get the proper diameter and spline count), but the bellhousing register and bolt pattern are both different.
Old May 19, 2005 | 11:06 PM
rs2600's Avatar
rs2600
Ok, a guy has one but he doesn't know which one it is. Any numbers that tells You if it's a Ford or not?Mat
Old May 20, 2005 | 09:30 AM
Putt's Avatar
Putt
Yes there are some numbers to look for. There is a small tag fastened to a rivet on the front, passenger side of the case. The tag is about 3/4" x 2" and will have a letter code like HEH-C. All of the Ford Top Loaders were made for Ford engines(I should have mentioned that), so if it is a Top Loader it will have the correct register altho it might have a different bellhousing bolt pattern and a diff length input shaft. Both of those diffs can be corrected.
The T10 will also have the small tag, I think in the same area. It will be like the Top Loader or a Ford number like C3AA-D, the letter code will be HEK-?(letter).
HTH
Old May 20, 2005 | 10:16 AM
rs2600's Avatar
rs2600
Thanks, Will try to check that.
Mat
80ford100
27
Jan 14, 2015 04:55 PM
EffunFiddy
Nov 13, 2013 03:29 PM
Davidson IronWorks
Jun 22, 2010 10:51 AM
moore1960
Oct 31, 2002 08:12 AM
ford351c
Jul 25, 2002 10:01 AM
