T18 Swap for NP435
Old Jul 22, 2002 | 09:12 AM
ford351c's Avatar
ford351c
Post T18 Swap for NP435
I am thinking of swapping a T18 for a NP435.
Will they line up?
Are shafts the same length?
Any other things I might run into before i decide
to do it or not.
Thanks in advance
Old Jul 22, 2002 | 09:45 AM
ringkong's Avatar
ringkong
T18 Swap for NP435
I don't know if it would be worth the trouble.
the T18 is a pretty stout tranny, I know I would not get rid of mine for anything.
Old Jul 22, 2002 | 12:07 PM
psychoXXX's Avatar
psychoXXX
T18 Swap for NP435
Man that T-18 can take anything and never dies why would you wanna get rid of it???
Old Jul 22, 2002 | 12:50 PM
82F100SWB's Avatar
82F100SWB
T18 Swap for NP435
The 435 does have a lower granny, but, it's only a marginal difference. As for putting it in, the case is a couple inches shorter.
Evan
1982 F100 SWB
300 HD: Cliffy 290H, 9.1:1 compression, forged everything, ARP'd bottom end/Hedman hedder/dual 2½" exhaust
NP 435/2.75 geared 9"
78 F150, 351M/C6, soon to be repowered with a 460
7? F?50 4x4, 250 badges, 150 running gear, 300/NP235/Married 205, D44/9"
Old Jul 23, 2002 | 03:47 PM
ford351c's Avatar
ford351c
T18 Swap for NP435
I misquoted myself. My NP435 has 2 broken
internal gears and a cracked top cover. I can get
a T-18 for less $$ than repairing the NP435. Thats the only
reason I'm considering the swap. But if they dont line
up or shaft problems then thats a different story. Just looking
for info if its worth fixing the NP or dropping in the T-18.
Thanks
Old Jul 25, 2002 | 09:53 AM
jalampi's Avatar
jalampi
T18 Swap for NP435
I had a T18 in my 79 while I was waiting for parts for my NP435. The T18 will bolt in but you will need the transfer case adapter. The transfer case is the same. I am asuming your truck is a 4x4.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
Old Jul 25, 2002 | 09:57 AM
jalampi's Avatar
jalampi
T18 Swap for NP435
If you are in Michigan I would be interested in your NP435 main shaft, if its a 4x4 trans.
Old Jul 25, 2002 | 10:01 AM
jalampi's Avatar
jalampi
T18 Swap for NP435
petrovich79f250
Dec 19, 2020 09:37 AM
chukar
Aug 13, 2016 06:53 PM
cipsmithers
Nov 28, 2008 01:04 AM
Slow
Nov 19, 2007 11:27 PM
tratrex
Apr 18, 2001 12:10 PM
