Computer Chips & Tuners
Power programmer ?
Old May 17, 2005 | 08:37 AM
slengland's Avatar
slengland
Thumbs up Power programmer ?
I have an 01 s-crew 5.4l 3.73, just put on 295\75\16's on 16x8's and obviously noticed a power drop. Do you guys think a power programmer will put me over or do u think i need to make engine mods? any thoughts will be appreciated. thanks
01 supercrew 5.4l 4x4
Old May 17, 2005 | 02:35 PM
ranchero77's Avatar
ranchero77
a programmer by itself is a drop in the bucket to get the power back to turn 3 1/2" taller than stock tires.
what kinda budget are you looking at?
Old May 17, 2005 | 03:24 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old May 17, 2005 | 05:26 PM
AG4.0's Avatar
AG4.0
It's definately a good place to start for the money. Might still be a tad slower than before, but it will definately make it better. Lower gears are probably the best bet overall to get that power back, but I don't know how much new gears cost. I'm guessing it's quite a bit more than a tuner, but probably a lot less than major engine mods.
Old May 18, 2005 | 02:54 AM
slengland's Avatar
slengland
I went from 265\70-17's so the actual deference is about 2", but a huge power drop, also they weigh more. I noticed a big difference when towing my trailer. I've already installed a K/N filter setup. Next I was going to add a programmer and exhaust. Just wanted to know if TB spacers or bigger TB's, or any other things I don't know about would help. I would like to keep the mods under 1K total.
Old May 18, 2005 | 08:17 AM
ranchero77's Avatar
ranchero77
I didn't realize you changed rim sizes. stock 16" should have been 255/70's.
you would see the most improvement with a set of gears, if you do the gear change yourself it can easily stay under your 1k budget.
I saw an article not too long ago 02 F150 5.4 with KN filter kit, borla exhaust and Jet programmer dynoed to only a 20hp increase. not too bad but still may not be enough to recoop what you lost.
Old May 22, 2005 | 12:43 PM
slengland's Avatar
slengland
OK sp the next ? is superchips or diablo, can find for same price but the predator model seems to have more adjustments and upgrades.
Old May 23, 2005 | 11:28 AM
FTE Ken's Avatar
FTE Ken
The Predator is the way to go for the most features. It will allow you to advance the timing as far as your local fuel quality will let you, for the most power:
http://www.motorhaven.com/home.php?cat=357
85robert
Dec 23, 2012 05:09 PM
bansheeduner
1997 - 2003 F150
18
Sep 4, 2008 02:32 PM
SFDWOWO
Modular V8 (4.6L, 5.4L)
May 26, 2007 06:45 PM
bla1879
1997 - 2003 F150
Apr 8, 2007 05:29 AM
