Sponsored by: Auxito
more power!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 9, 2008 | 04:30 AM
bansheeduner's Avatar
bansheeduner
i have an 01 f150 s crew 4x4 5.4l auto trans it has exhaust intake and 35 inch tires i am debating between an edge programmer or hypertech which one is better???? i wants alot more torque and power. whats the best way to get more power out of these trucks minus supercharger or nitrous???
Old Aug 9, 2008 | 08:02 AM
advocate's Avatar
advocate
Get some gears to make up for the tires - if you haven't already. Then get a programmer so you can adjust your tire size making your speedo correct, while giving you a bump in power and making your trans shift much better.
Old Aug 9, 2008 | 01:10 PM
rebelyell618's Avatar
rebelyell618
+1 on gear that will be the best bang for the buck on performance.
Old Aug 9, 2008 | 03:31 PM
bansheeduner
so edge or hypertech
Old Aug 9, 2008 | 04:02 PM
lariat97's Avatar
lariat97
I'd pick the edge over hypertech but if it was my choice I'd buy a SCT Xcal 2 or 3 with custom tunes after I changed the gears. Those tall tires are killing your power.Also don't expect a huge power increase from a programmer on a gas motor.
Old Aug 9, 2008 | 04:26 PM
o_i_f_03_04's Avatar
o_i_f_03_04
If your in a hot area i heard electric fans really help from losing power and with a slight bit of fuel mileage increase
Old Aug 9, 2008 | 04:43 PM
LxMan1's Avatar
LxMan1
Predator and 4.56 gears!!
Old Aug 9, 2008 | 05:12 PM
xtrford's Avatar
xtrford
Xcal-3 with 4:56 gears!!
Sorry Lxman1...couldn't resist.
Old Aug 9, 2008 | 06:43 PM
Bobby82490's Avatar
Bobby82490
Although it is more expensive.. you would notice a VERY BIG difference if you got gears. While a tuner would give you gains.. it would be small, esp. with those big tires.
You would be better off to save up for gears, than to spend $300+ for something you might not be happy with.
Old Aug 9, 2008 | 09:38 PM
Ultramagdan's Avatar
Ultramagdan
E-fans are nice but won't deliver a performance increases with the package you want. You mention you want a lot more preformance, for that you will need to dig deep. Gears will be the cheapest but they still have a price on the highway.
Old Aug 9, 2008 | 10:07 PM
o_i_f_03_04
I didnt say that e fans would deliver performance but the belt driven fan in my truck steals alot of performance outa my truck when it kicks on. I agree with the 4:56 gears that will be my next mod.
Old Aug 10, 2008 | 06:49 AM
kaboom10's Avatar
kaboom10
YYYYYYYYYYEEEEEEEEEEESSSSSSSSS
Old Aug 10, 2008 | 02:11 PM
bansheeduner
i have gears on the way but what about cams or port and polish
Old Aug 10, 2008 | 03:25 PM
Bobby82490's Avatar
Bobby82490
What ratio are you going with?
Old Aug 10, 2008 | 05:18 PM
LxMan1's Avatar
LxMan1
They (cams and ported heads) will increase power in the upper rpm range, but will kill some low end torque.
