Steering box leaking
Old May 16, 2005 | 02:53 PM
mj1990buildup's Avatar
mj1990buildup
Just like the title says. It's not coming from the top lines, it appears to be dripping off the pitman arm. Is there any way to put some new seals in this box or am i just looking at getting a new one. and by new i mean junkyard of course.
Old May 16, 2005 | 03:34 PM
travisd's Avatar
travisd
Yes, they do make pitman arm seals. Not too big of a job, just remember the orientation of everything as it comes off.
Old May 16, 2005 | 07:58 PM
plowpusher's Avatar
plowpusher
rent a pitman arm puller you'll need it make sure the replacement seal goes in straight
Old May 17, 2005 | 12:15 PM
mj1990buildup
is it crucial for the seal to be pressed in or could i finesse it in with a mallot?
Old May 17, 2005 | 03:28 PM
kermmydog's Avatar
kermmydog
If all of the work sounds like too much work go buy some Lucas Auto Trans Stop Leak, that won't stop it completely but will slow it down bunches.
If the pitman seal is leaking there are two major reasons, one the seal is dried out and hard, or two the box is getting close to being wore out.
I did exactly as I have shared with you and got by for three years, finally changed the gear box. I paid $167.00 for a rebuilt box from Car Quest.
xtremexj
Apr 14, 2013 12:52 AM
diesel-fitter-bum01
13
Mar 26, 2012 04:58 AM
roostercrows
Sep 26, 2010 07:20 PM
pinestar
2009 - 2014 F150
Jun 28, 2009 06:42 PM
67nukeford
Mar 29, 2006 11:13 AM
