Windshield washers??
Old May 12, 2005 | 07:12 PM
Madathlon's Avatar
Madathlon
I have a 1960 F-100 that from what I see has never had a windshield washer in it.. Im not worried about it eing OEM but what combition of parts have your Guys/gals used in this case?
Old May 12, 2005 | 07:54 PM
AXracer's Avatar
AXracer
I'm using the bottle and pump assembly from a 99+ Mazda Miata. It's relatively compact, the pump is built into the tank and it has mounting ears to screw it to the firewall or inner fender panel or ???
Old May 12, 2005 | 09:31 PM
Madathlon's Avatar
Madathlon
What about the sparyer part?
Old May 12, 2005 | 10:10 PM
laynrubber's Avatar
laynrubber
I have a square tank from a 78 F100 and just bought some generic tubing and tube splitters. The spray nozzles, I don't know..........hhmmmm they were already in the truck come to think of it.
Old May 12, 2005 | 11:12 PM
AXracer's Avatar
AXracer
Mine already has the nozzle on the hood, you could use one of the hood mounted ones (Miata uses this type as well) or the stealth type from a late model car with hidden wipers, many used separate little tubes that mounted to the back edge of the cowl that could be adapted to mount under the back edge of the hood. I may end up changing over to that type eventually just to keep the hood clean. If you wanted more bling, they sell replacement nozzles that light up in different colors to the tuner crowd.
Old May 12, 2005 | 11:26 PM
Madathlon's Avatar
Madathlon
Im not into the Bling stuff.. I like simple.. Much easyer to work with
johnmel59
Jan 15, 2014 10:59 PM
1954_NJ_F100
Jul 9, 2012 08:25 AM
Myfreeford
Jan 4, 2012 06:22 PM
Chea77F150
Dec 21, 2011 04:26 PM
tripticker
16
Sep 3, 2003 06:37 AM
