Windshield Washer Hookup????
Old Sep 1, 2003 | 07:19 PM
tripticker's Avatar
tripticker
Okay you techy guru's.......my windshielf washer reservoir and pump were missing when I got my '67 F-100. I have found a reservoir and pump that will work and I have room on the inside of the driverside fender well for a nice snug fit. Problem is what wires power the windshield washer pump?
Thanks in advance for any help.......
Old Sep 1, 2003 | 07:32 PM
Comegetsome's Avatar
Comegetsome
In my '67 the stock pump and reservoir bag are mounted to the drivers side inner fender. Power is supplied by a single black wire exiting the firewall. It should be easy enough to trace the wiring from the pump switch, in the cab.
Old Sep 1, 2003 | 07:50 PM
tripticker's Avatar
tripticker
Comegetsome,
Thanks for the info. The problem I am having is there are two connections on the windshield washer pump. Will just one wire power it?
I appreciate the help.
Thanks again.
Old Sep 1, 2003 | 08:01 PM
sparky's Avatar
sparky
The wires to the plug could be green/black stripe (power) and black (ground), I do not have a color code for a 67 so I used a 69 instead. Hopefully it is close
Old Sep 1, 2003 | 08:02 PM
tripticker's Avatar
tripticker
Comegetsome,
Do you have a photo of your windshield setup you could post here on FTE? I would really like to see what an original setup looks like.
Thanks.
Old Sep 1, 2003 | 08:04 PM
tripticker's Avatar
tripticker
Thanks Sparky, I'll take a look and see what kind of wire I can find hanging loose.
Appreciate the help.
Old Sep 1, 2003 | 08:29 PM
Comegetsome
<img src="http://www.members.shaw.ca/mtidder/images/ww1.gif">
<img src="http://www.members.shaw.ca/mtidder/images/ww2.gif">
Old Sep 1, 2003 | 08:34 PM
Comegetsome
tripticker, let me know if those pics help you out. I cut the size down quite a bit, so if need be I can send you a link for the originals.
Old Sep 2, 2003 | 06:08 AM
tripticker's Avatar
tripticker
Comegetsome,
Thanks for the photos. They are a tremendous help and I am sure many others will benefit from them also. That is the first time I have seen the original setup for the bladder bag and washer motor on the '67 Ford F-100. How have you kept that bag looking so new? I have looked at a lot of trucks over the last few months and all those original bags and motors are long gone.
By the way, is that only one wire I see going into the windshield washer pump?
Thanks again. You are going to be a great asset to the FTE community.
Old Sep 2, 2003 | 06:10 AM
tripticker's Avatar
tripticker
Comegetsome,
It looks like it could be two wires wrapped going into the plug.
Would it be possible for you to take the plug off and send a pic of the configuration of the plug itself? I hope I am not being a pita.
Appreciate your help.
Thanks again.
Old Sep 2, 2003 | 04:37 PM
tripticker's Avatar
tripticker
Thumbs up Windshield Washer Hookup????
Comegetsome,
I found my old windshield washer wire. I found it crumpled up under the power steering box. Apparently when the PSB was swapped out it got caught and pushed down. Anyway your picture told me what to look for so thanks again for the timely photos.
Everythings okay with the windshield washer now.....on to the next project.
Old Sep 2, 2003 | 06:51 PM
Comegetsome
Glad I could help.
Old Sep 2, 2003 | 08:54 PM
tripticker's Avatar
tripticker
Hey Comegetsome and Sparky,
Got it going and the washers work perfectly. Thanks for taking your time to help me. I have a photo of the reservoir I took off of a '72 F-100 for $2.00 at the junkyard and a new pump motor from the parts store and it looks like a factory setup. Photo below:
[IMG][/IMG]
I wish I could have found one of the FoMoCo Washer Bags like Comegetsome has on his truck. I would have restored it back to original. Oh well. One more project under my belt. Now on to the the next challenge.
Thanks again fellas.
Old Sep 2, 2003 | 09:06 PM
Mil1ion's Avatar
Mil1ion
Any Mustang parts place will have one.
They used the same thing on many models.
Old Sep 2, 2003 | 11:12 PM
tripticker's Avatar
tripticker
Thanks Dennis. I appreciate the input.
