weird short
Old May 11, 2005 | 06:44 PM
baitmaster's Avatar
baitmaster
weird short
Here's a weird one... The other day I had the truck idling with the hood open. I could hear a "snapping" sound, kind of like a spark plug wire shorting to a ground. Couldnt see anything, so waited til dark and started 'er up. Had a blue spark jumping from one pwr steer hose to the other pwr steer hose where the metal in the hoses were close to each other. What is this?
Old May 11, 2005 | 07:00 PM
tjbeggs's Avatar
tjbeggs
sounds like static electricity to me. not sure if its possible but can't think of how the power would be there.
call a new station and make some money off the freak show!!!
tim
Old May 11, 2005 | 07:12 PM
baitmaster's Avatar
baitmaster
my first thought
Thats what my first thought was, static electricity. I'm thinking: What now, ground wire to my pwr steer pump? This is a spark that isnt intermittent, but looks like the spark on a shorted plug wire when it jumps to the headers. And it's blue, so it must have some juice to it...
Old May 11, 2005 | 09:52 PM
Franklin2's Avatar
Franklin2
Pull each sparkplug wire off, one at a time from the distributor cap, and see if it quits doing it. Also try to notice if the engine idles rougher after taking each wire off. You may find one that makes it quit sparking, and also does not affect the idle quality. This is the wire you need to concentrate on.
Old May 13, 2005 | 07:13 PM
baitmaster's Avatar
baitmaster
This is a spark between my pwr steer hoses, they are at least 6" away from any plug wire. Motor runs fine.
Old May 15, 2005 | 12:18 AM
Franklin2's Avatar
Franklin2
If the snapping frequency goes up and down with the motor rpm, it has got to be coming from somewhere in the spark system.
Old May 17, 2005 | 07:03 PM
baitmaster's Avatar
baitmaster
gotta rev it
Didnt rev the truck to see if the sparking increased in frequency. This started about the time I installed new 1 wire Ford Alternator. I have also noticed that when I hook battery cable to solenoid with switch off, there is a noticeable spark there. Shouldn't be any, I would think. Will have to start pulling fuses and see if its anything in the fuse block, or maybe ignition. I remember reading a post several mo ago, about someone that had put a 1 wire in their truck and had to install a second solenoid to remedy some hot wire prob. Really dont want to do it that way, but if I cant find this, maybe I will.
Old May 17, 2005 | 09:47 PM
Franklin2's Avatar
Franklin2
12 volts is not going to jump an air gap. It will have to be in the thousands of volts to make air conduct electricity. It's either static, or high voltage from somewhere, and the obvious place to look for high voltage is the ignition system.
Old May 19, 2005 | 07:18 PM
baitmaster's Avatar
baitmaster
mystery wire
When I installed the 1 wire alt, I found a wire off of the old reg that seemed to power everything on the truck, including ignition switch. I'm thinking that possibly one of the wires from the reg wasn't hot all the time, wondering if the coil is still hot, or a leg on the ignition switch that needs to be switched off instead of constant 12 volts. Would the coil have a hot side if the key is off? Also, when I reconnect the battery cable to the hot side of solenoid, I hear a clicking sound, possibly from inside the truck. What would this be? this is a 72 F-100
Old May 19, 2005 | 08:06 PM
Franklin2's Avatar
Franklin2
Are you talking about the ignition coil? If so, no it's dead unless the key is turned on.
cookster351
197
Jan 17, 2023 12:33 AM
Hitokori
Jan 1, 2010 01:25 AM
supercab79
Feb 15, 2004 07:54 PM
98Stang
27
Sep 21, 2003 02:08 AM
pwrstroke
May 13, 2002 04:30 AM
