cigar lighter fuse problem
Old May 16, 2005 | 04:39 PM
ghades's Avatar
ghades
what up guy i maybe one of u can help me out well my cigar lighter fuse gets gettting burn i dont know why fuse after fuse any ideas it was working fine no i dont know what the problem is
Old May 16, 2005 | 05:22 PM
cangim's Avatar
cangim
What are you plugging into you cigar lighter fuse? if anything?
Old May 16, 2005 | 07:05 PM
Franklin2's Avatar
Franklin2
Does everything else still work? I am thinking there may be more than one thing on that circuit. Or if there isn't maybe someone spliced into it behind the dash for some accessories.
Old May 17, 2005 | 03:10 PM
ghades's Avatar
ghades
nop
its just the ligther evrey thing else still works
Old May 17, 2005 | 09:56 PM
Franklin2's Avatar
Franklin2
Can you get behind the lighter and unplug the wire feeding it? Then you could try another fuse to see if it's the socket.
Old May 17, 2005 | 10:34 PM
cangim's Avatar
cangim
Is the fuse popping even if nothing is plugged in?
Old May 19, 2005 | 09:47 AM
ghades's Avatar
ghades
well/???
the thing is that i can put the fuse but when i turn my truck on the fuse goes boom well u get the point
Old May 19, 2005 | 08:12 PM
Franklin2's Avatar
Franklin2
I thought the cigarette lighter was hot all the time?
I just looked at a 1999 diagram, and the cigarette lighter is hot all the time, and it does have it's own fuse. If your truck is the same, then the fuse should blow the instant you install it, not when you turn the key.
Whitey Ford
20
Dec 14, 2019 11:41 AM
chardagha
Jul 12, 2016 11:24 AM
FORD E-150
1997 - 2003 F150
Feb 28, 2015 07:43 AM
Moe Craig
15
Oct 30, 2013 02:10 AM
cobraguy
Aug 24, 2002 12:59 AM
