4 wheel drive problem
Old Apr 23, 2000 | 09:55 PM
Beeawtch's Avatar
Beeawtch
There is something very wrong with my front axle. When engaged it will work fine for about 10 feet then a HUGE clang will be heard and the front end will no longer pull. It has gotten me stuck several times. I've rebuilt the the transfer case( np208 ), and have had two sets of hubs on it. Is it possibly the lack of a crossmember for the transfer case? ( mine was taken off or broken by the last owner ) I'm planning on replacing the TTB w/ a strait axle using leaf springs and I can't have the vehicle torn apart for more than a couple of days or my neighbors complain to the city and the cops show up with a summons for court. Both drive shafts have also been rebuilt. I've been told so many different possiblities for the problem I can't tell the remedies from the B.S.
Old Apr 24, 2000 | 09:30 AM
PAUL_2's Avatar
PAUL_2
What model and year is your truck ? What led to the rebuilding of the transfer case ? Are the front axles Ok ? What front end ? Manual or auto locking hubs ? Have you checked to make sure the front ring and pinion gears are Ok ? Give us some more details so we can possibly help you out ?
Paul
Old Apr 25, 2000 | 01:07 AM
Beeawtch's Avatar
Beeawtch
'81 model, new u-joints put on recently, outer stub shafts fine shape, manual hubs, can't pull front end apart more than once or I'll be sued by the city Gov't and they will confiscate my truck. ( Facist neighbors whom happen to sit on city council ) There is a city ordinance stating that any serious rebuild or overhaul of vehicle must be in a garage or enclosed area out of sight of the public. ( Eyesores )
The inner shaft on the passenger side appears OK, no loosness, no leaking. If it is the gears it must be side gears or pinion shaft because I can see the ring gear through the fill hole.No visual damage.
If you think the city rules are draconian, listen to this. They are making me move my dad's 78 F-250 from out of my own driveway, saying it is a safety hazard and blocks traffic. The nerve!!!
Old Apr 25, 2000 | 05:32 AM
Torky's Avatar
Torky
Maybe if you were working on some sort of nice pedal powered Eco-bike, then maybe your town just might tolerate it!
Just curious, what happens if you keep transfer case in 2wd, and lock the hubs? Will the front wheels drive through the front diff and spin front driveshaft OK, no clang?
Old Apr 25, 2000 | 03:34 PM
Nathan's Avatar
Nathan
Dude, "MOVE"!! This is America, you know!!
Nathan
Old Apr 25, 2000 | 10:11 PM
Beeawtch's Avatar
Beeawtch
Man, if I could afford to move I would !!!!!!!!!!!!
Old Apr 25, 2000 | 10:30 PM
Beeawtch's Avatar
Beeawtch
I can't be sure, but I think it only happens when under a load from the engine or when on incline. The sound is comparable to hitting the front diff. with a sledgehammer and it actually makes the truck shudder. My best guess is the side gears are broke, bearing retainers are broke or the whole carrier itself bad.
The previous owner used to junp the truck out of creek beds and over small hills. I didn't find out about this until I had sunk alot of dough into a new body and paint. ( I mean the whole truck, other than the cab which was repaired, has either new or remanufactured body parts.)
Oh, by the way, where is the cheapest place to get my NP435 rebuilt? Third and fourth gear scream and rattle.
Old Apr 25, 2000 | 11:11 PM
timmgill's Avatar
timmgill
natoriusbob
1997 - 2003 F150
Dec 5, 2011 11:50 PM
johaner78
Sep 7, 2011 09:45 PM
smashclash
Sep 7, 2010 08:22 AM
acm05fsu
1997 - 2003 F150
19
May 1, 2010 09:56 PM
dagray3
Jun 10, 2003 04:46 PM
