Fe 428
Old May 10, 2005 | 06:47 AM
BigWindowJim's Avatar
BigWindowJim
Fe 428
Looking for information on how to identify an FE engine. I think I have a 428 car engine, but am not sure.
Old May 17, 2005 | 04:49 PM
mike390's Avatar
mike390
more than likely if its a fe series it will have 352 cast on to the front of the engine block here are the casting numbers for the 428. If its non of these post your casting numbers and i'll be glad to find out what it is
c6ae-a
c6ae-b (police block)
c6ae-f (police block)
c6me
c6me-a
c7me
c7me-a
c8me (cobra jet)
Old May 18, 2005 | 05:12 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old May 18, 2005 | 05:21 AM
gtex's Avatar
gtex
5 valve cover bolts, that's a good place to start looking.
Old May 18, 2005 | 06:53 AM
bshackelford711's Avatar
bshackelford711
length of the stroke
Old May 18, 2005 | 09:46 AM
Six Niner's Avatar
Six Niner
valve cover covers part of intake manifold.
Old May 18, 2005 | 12:55 PM
kwanderi's Avatar
kwanderi
Where can one find the casting numbers on the block?
Keith
Old May 19, 2005 | 01:27 AM
ford390gashog's Avatar
ford390gashog
mike390 are all c8me blocks cobra jet what about c8me-a
Old May 19, 2005 | 10:31 AM
Mike G's Avatar
Mike G
C8ME can also be found on 330 and 391 FT blocks. The CobraJet blocks had a sand cast scrathed A or C on the back face of the block.
BigWindow, the problem with an FE is most of them are alike from the outside, you really need to find what the stroke and bore of the motor are to zero in on displacement. Take a look at my pictures, it's nearly impossible to tell the old 352 from the +.060 over 390 I now run, except one is cleaner
--Mike
Old May 19, 2005 | 07:04 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
It was the std 428 block that has the "A" on the rear of the block. The CJ and SCJ the "C" on the rear of the block. Mike G is right on track. It's really difficult to ID the engine together and in a truck/car without removing some parts. The casting numbers are generic making them PMU.
Kwanderi, The casting numbers are on the right (pass) side of the block.
Old May 19, 2005 | 08:28 PM
ford390gashog
i went out to my garage to check on the engine with the c8me and after pulling theflexplate i found a very crude "c" so does that make it a 428 cj it also has c8ae-h heads it is all original but is in poor shape it was run with low oil and spun some rod bearings
Old May 20, 2005 | 04:52 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yep sounds like a CJ block to me.
G.
72CC428
15
Jun 5, 2016 02:08 PM
cysneed
17
Nov 10, 2011 01:16 PM
FE 390
13
Sep 26, 2003 08:51 PM
carrojp
23
Feb 21, 2003 01:34 PM
Nitro
16
Mar 3, 2001 06:53 AM
