Fuel pump running----WHY?
Old Oct 13, 2010 | 06:53 AM
ArdB's Avatar
ArdB
Fuel pump running w/o key on.
1983 460 Econoline motor home. twin fuel tanks
Put rebuilt 460 engine back in and reconnected wiring. Hooked up battery and fuel pump began pumping. Key is not even in the switch.
I did not think there should be any current available to pump unless key in start position or oil pressure up with engine running.
Have I missed something.
Help appreciated. Ard
ardb@aol.com
Old Oct 18, 2010 | 08:47 AM
ArdB's Avatar
ArdB
Problem fixed.
Vehicle had been sitting outside w/o hood. Fuel pump relays were hanging by wires behind battery out of sight. fuel pump shut off relay that follow inertia switch was full of water and grounded out.
ArdB
Jan 16, 2011 04:25 PM
ArdB
Oct 15, 2010 10:51 PM
ArdB
Sep 6, 2010 03:06 PM
ArdB
Feb 26, 2010 03:45 PM
