Air Conditioning Questions?
Old May 9, 2005 | 02:52 AM
rutang's Avatar
rutang
Hi, I am buying a 1978 F250 and was wondering how hard it is (or if it is possible) to install air conditioning into a truck that doesn't come stock with AC. Or is their some sort of aftermarket...under the dash kind of setup? Thanks for the help!
Rusty
Old May 9, 2005 | 04:03 AM
pfogle's Avatar
pfogle
All you need to do is find another truck in the scrapyard with the a/c option. Then get all the required dash panels, ductwork, and heater box. Then purchase a NEW compressor, evaporator, lines, and heater core.
Old May 9, 2005 | 10:09 AM
73Custom's Avatar
73Custom
Like pfogle said, just find a parts truck and swap the entire heat/a/c system over to yours. I did this to mine last summer and it was pretty easy. A large hole needs to be cut into the fire wall, just make a cardboard template off the parts truck and use a sawzall to cut it. Once I got the parts from the salvage yard, it took a afternoon to cut the hole and swap the parts onto my '73. Search through past posts for step by step instructions.
Marty
Old May 10, 2005 | 01:19 AM
deisele75's Avatar
deisele75
If you want all new stuff and a nice little warrenty to go with it, check out www.vintageair.com
redsplashman
2004 - 2008 F150
41
Jun 10, 2007 08:28 PM
teamwizard
1997 - 2003 F150
Aug 10, 2005 08:00 AM
madman666
Dec 19, 2001 02:41 AM
Sep 1, 2000 11:23 AM
ummduh
Feb 16, 2000 07:01 AM
