Moog Upper Ball Joint Boot
Old May 8, 2005 | 10:15 AM
werknman's Avatar
werknman
OK, believe it or not the hard part for me in replacing the ball joints is getting the upper ball joint boot on. It is a moog ball joint and for the life of me I can not get the boot over the lip, any ideas??????
Old May 8, 2005 | 03:17 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I'm sure someone that has done this job will give you some help.
Old May 9, 2005 | 08:07 AM
greenpus's Avatar
greenpus
the boot on the moogs are not meant to go over the lip. When you put the spindle into the upper arm the pressure will squeeze the boot. IT is not meant to be air tight or grease tight. THere is a hole in the boot. that hole has the be pointed towards the opposite tire. if you put the hole on the same side as the brake the grease will leak out on to your brake rotor
Old May 9, 2005 | 08:25 AM
werknman's Avatar
werknman
greenpus, thanks for your reply. I finally gave up and installed them the way you describe, as I figured there was no way in hades that those boots would ever go over the lip. Thanks again!
pawpaw
20
Aug 10, 2012 06:29 AM
ford1/2ton
1997 - 2003 F150
Aug 16, 2009 07:10 AM
95Z71
Feb 1, 2008 10:29 PM
soahnk
Sep 21, 2005 10:02 PM
Zcarbuilder
Aug 21, 2004 09:20 AM
