egr problem
Old May 3, 2005 | 08:32 PM
81rangerF150's Avatar
81rangerF150
egr problem
I've got an 81 351m with egr.... i recently rebuilt the carb and since then, the engine doesn't run properly with the egr connected (bogs down just past idle).
If i disconnect the egr vac. ,it runs fine. I haven't changed the routing of any vac lines... i know i could just get rid of the whole egr system, but i would like to have it working again regardless...
thanks, Dave
Old May 3, 2005 | 08:40 PM
reamer's Avatar
reamer
Does it have an EGR "plate" under the carb?
My '74 Bronco with a 302 had the same problem. The plate under the carb was full of carbon, all the ports were plugged up. cleaned out the plate and she was "good to go"
Reamer
Old May 3, 2005 | 11:38 PM
Jebadiah04's Avatar
Jebadiah04
in my an 86 witha 300 i just took the EGR off and made me up a plate that covers up the ports. All better, better miliage and better power too.
Unless you have emissions tests, then just clean it out.
Old May 4, 2005 | 02:40 AM
fellro86's Avatar
fellro86
the egr may be hanging up, try taking it off and soak it in WD 40 or something similar. by this I mean the pintle side that is inside the valve that passes the gasses.Do not spray it into the diaphragm or soak it, just the valve end. A friend of mine couldn't get his 80 F150 to idle, and that was the cause, it was stuck well open, turned out to be just carboned up.
Old May 4, 2005 | 08:13 AM
Dustin_86's Avatar
Dustin_86
Sorry to hyjack this thread but on my 86 EFI 302 where is the EGR valve located? I want to try to soak it in B-12 so see it it clears up my rough idel/surging. I have already cleaned the IAC vaave so it made a slight diffrence.
Dustin
Old May 4, 2005 | 03:14 PM
Jebadiah04's Avatar
Jebadiah04
Its goofy lookin round thing that comes off your intake, right beneath your Carb... 302 i think it stick out the back (correct me on this one) but def. on the intake manifold.
and yes egrs love to give u rough idle/surging
Old May 4, 2005 | 05:57 PM
81rangerF150
thanks guys, guess I'll prob just plug 'er up and forget about it. That means i could lose the air pump too...
Old May 5, 2005 | 12:58 AM
Jebadiah04's Avatar
Jebadiah04
i just strip all mine clean of smog stuff...but then again..im a redneck
Old May 5, 2005 | 05:54 AM
reamer's Avatar
reamer
On the '86 EFI, it's right up front, to the left (looking at the firewall) hanging off the plenum. If you get a code "31" there's a fix for that too.
dumper
Large Truck
May 12, 2013 09:58 AM
fastbmw01
19
Jul 29, 2011 12:36 AM
masseysbronco
Aug 12, 2010 09:58 AM
goincrazie01
Feb 11, 2010 07:34 AM
dorymate88
Electrical Systems/Wiring
Dec 30, 2008 01:31 PM
