egr question
Old Feb 10, 2010 | 07:00 PM
goincrazie01's Avatar
goincrazie01
egr question
If I can unplug the vac line to my egr to make my bronco run better can someone tell me why i need to do the egr plate with the hole drilled in it.
Old Feb 10, 2010 | 07:55 PM
300 Buster's Avatar
300 Buster
I don't know about the hole,but if you put a tin plate in,it eliminates the EGR totally and any future problems,like the valve leaking exhaust into your intake and what ever.Just be sure to block that vac line so you don't get a leak there.It may work a long time like you have it,but with it blocked at the port it can't create more problems.Prior to computers,we used to just totally block them with tin,maybe the hole has something to do with allowing something in the system to work,I'm not sure about that,but the way you have it is considered a temperary fix.
Old Feb 11, 2010 | 07:34 AM
goincrazie01
egr
I failed to mention its a 90 model bronco, anybody else care to reply to my question?
grantpage
Oct 10, 2011 08:06 PM
bkvanbek
Jan 10, 2009 12:27 AM
theguy_88
Jan 1, 2008 12:41 PM
skelator
Jun 23, 2004 01:15 AM
powerram50
Aug 1, 2003 06:47 PM
