67 column bearing
Old May 3, 2005 | 07:52 PM
dj8667's Avatar
dj8667
67 column bearing
I have a 67 f-350 the bearing in the bottom of the steering column is gone and allowing the steering wheel/column to pull up and twist the rag joint. Does anyone know if the bearing can be replaced if so where can you get it. or do i have to find a new column for it.. will a 70's or 80's truck column work.. Thanks, DJ
Old May 4, 2005 | 10:36 AM
qman's Avatar
qman
You can get the parts at the Ford dealer and it's real easy to rebuild the colunn all by yourself. Check this out:
https://www.ford-trucks.com/forums/s...d.php?t=368362
Old May 4, 2005 | 10:16 PM
jlasater's Avatar
jlasater
While you're at it, replace the steering coupler (aka rag joint). They are cheap. Mine fell apart while removing the steering column. I had no idea it was so far gone. It had looked fine.
idealtrucks
Nov 7, 2016 03:04 PM
BM19
19
Jul 26, 2016 07:57 PM
DuallyF350
May 12, 2015 08:12 PM
fishmanndotcom
May 12, 2011 09:12 PM
Heath67
Oct 16, 2006 03:21 PM
