Lower steering column bearings
Old Nov 3, 2016 | 07:44 PM
idealtrucks's Avatar
idealtrucks
Is it possible for a string column to be too bad to rebuild? I have a power steering column i was planning on using, but bearings are all shot in it. I know that the uppers can be changed, but I'm not sure about the bottoms. The shaft is very rusty, but doesn't appear to be worn. When I took it apart, the pieces of what was left just fell out. What I can assume is the race in the end of the tube looks a little worn
Old Nov 3, 2016 | 08:22 PM
ultraranger's Avatar
ultraranger
Hard to say for sure but, it looks like to me the open end of the column tube has been sawing on the steering shaft (looks like there's a rusty groove present in it).
If this is so, that's usually an indication that either the metal cab mounts are rusted/rusting out or, that the rubber cab mounts are old and compressed/collapsed.
If either of these conditions are present, it'll pitch the cab. If the front cab mounts are rusted or the rubber mounts compressed, it'll pitch the front end of the cab downward. Since the column tube attaches to the dash and the engine side of the firewall, this will put a downward force and strain on the steering shaft. This will place a bind on the lower column bearing and eventually chew it up and all of the lower bearing will simply disentegrate, fall out and disappear. With nothing left to keep the steering shaft centered in the column tube, the open end of the tube will start gnawing on the steering shaft.
If the rear cab mounts are bad, the back end of the cab will drop down and the forward end of the cab will be pitched upwards, causing the column tube to do the same thing to the bearing and steering shaft, only, the tube will be sawing on the underside of the steering shaft.
This is the result of compressed rear rubber cab mounts to the old fixed column steering shaft (where the awl is pointing) that used to be on my '69 F100.
Groove cut into steering shaft. A good portion of the clamp and nearly half the head of the bolt and the hex of the nut were worn away where they had been dragging around against the inner portion of the column tube, at the open end of the tube. The stress of the cab being out of alignment (caused by the rubber cab mounts) destroyed the (raggedy) rag joint.
Old Nov 3, 2016 | 09:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by idealtrucks
Is it possible for a steering column to be too bad to rebuild? I have a power steering column i was planning on using, but bearings are all shot in it. I know that the uppers can be changed, but I'm not sure about the bottoms.
What year is the steering column? If it's from a 1967 thru 1973 F100/250 2WD, the upper and lower bearings (C3DZ-3517-A) are the same and are available from Ford.
The lower steering column bearing retainer (C5TZ-3D681-A) is reproduced
This bearing was also used on some 1961/66's, 1974/79's, misc Ford/Merc Passenger Cars like 1965/66 Mustang's.
Old Nov 4, 2016 | 05:26 PM
idealtrucks
It appears to be a 71 or 72 column. I've attached some pictures of what came out and the end of the column tube. From the pics, do you think it would be alright to rebuild? I'm not sure what the pieces are that I'm looking at, in relation to the part numbers listed above. I know the retainer is the clamp on the end.
Old Nov 4, 2016 | 05:42 PM
NumberDummy
The white piece is the remains of B1AZ-3518-A .. Upper or Lower Steering Column Bearing Nylon Sleeve
Don't recognize the other parts.
Pic of steering column: 1965/72 F100/250 2WD & 1967/72 F350.
Bearings shown as 3517 .. sleeves shown as 3518
Old Nov 4, 2016 | 06:08 PM
idealtrucks
What is part 3510?
Old Nov 4, 2016 | 06:15 PM
NumberDummy
What is part 3510?
3510 = Retainer-Steering Column Lower Bearing Seal. Two different types.
Old Nov 4, 2016 | 07:25 PM
JEFFFAFA's Avatar
JEFFFAFA
I think the center piece is part of the 3517. The piece on the right is the 3510.
edit
Can't be a 3510. Both choices are listed as thicker than the one in the pic. So the center and right pieces in the pick have to be both halves of the 3517 bearing.
Old Nov 7, 2016 | 09:18 AM
idealtrucks
What do you think the piece on the left is?
Old Nov 7, 2016 | 03:04 PM
JEFFFAFA's Avatar
JEFFFAFA
Well, the only thing left is the 3510. But the way they describe it doesn't sound right. Here is how the 3510 is listed for a Bump:
65/69 F100/250 (4X2), 65/69 F350 before ser #D96,001, ALL, D0TZ3510A.(replaced C5TZ3510A) Replaced by D0TZ3510B.
69/72 F100/250 (4X2), 69/72 F350 after ser #D96,001, also D0TZ3510B when used with 3 speed manual-manual steering, auto trans-manual steering, 4 speed -manual or P/S.
D0TZ3510B is 1 5/16" O.D. X 3/8" thick.
69/72 F100/250 (4X2) , 69/72 F350 after ser #D96,001, C9TZ3510A. When used with P/S with 3 speed or A/T.
C9TZ3510A is 1 5/16" O.D. X 1/2" thick. This one has 2 tapped holes.
R. Tovar
18
Nov 19, 2014 06:28 PM
shack
Mar 19, 2009 12:14 PM
Customcab
Nov 21, 2008 01:26 PM
Seifferlein
Aug 11, 2005 08:53 PM
MAHinton
Feb 7, 2005 01:47 AM
