The kwik filter
Old May 4, 2005 | 07:52 AM
mueckster's Avatar
mueckster
If the paper used on the NAPA filter is the same as the Donaldson, it is chemically treated to reduce the absorption of water. I have not had any problems during rainy weather or when washing the truck. I use Luberfiner filters with a tag that stated it was the same Microlite* paper. Also, I connected the filter to the hose with a short section of 4" exhaust pipe. I used the HD band clamp on the filter end.
Old May 4, 2005 | 10:58 AM
tex1313's Avatar
tex1313
I think that I also got one of the new filters a couple of weeks ago because there was no way that thing was going into the intake line. I just went to the hardware store and bought a 4" rubber pvc pipe coupling. It came with the clamps on it and has worked great! I like what 77hiboyboy did about siliconing it in. Going to give that a whirl. I would say save your money and go with the "kwik" filter and not the Tymar. Just my .02 worth though!
tex1313
Old May 4, 2005 | 03:26 PM
77hiboyboy's Avatar
77hiboyboy
I use a luber finer, just curious but what did yours cost you?? Mine was 26 bucks. Tex1313 the silicone works good, I use the self-propelled can and just run a bead around all the joints, but I would reccomend covering the filter and spraying with ether and seeing if it raised the motor speed, would tell you for sure if you had any leaks.
Old May 5, 2005 | 08:02 AM
mueckster's Avatar
mueckster
77hiboyboy,
I get mine from our company's parts supplier salesman and pay about $20. I use the LAF2533. I also use the Luberfiner fuel filters for about $13.
Old May 6, 2005 | 11:15 PM
77hiboyboy's Avatar
77hiboyboy
77hiboyboy,
The place I got mine always treats us really good on parts, but that is comparing to the local places here, I will try to beat some more out of them, but they had only ordered one other filter like that and it was for a skid-steer??
Old May 7, 2005 | 08:40 AM
kc2006's Avatar
kc2006
back when i did this "kwik filter" about 2 years ago before it was the "kwik filter" I searched for a filter that would have a lip on the bottom so you can use a band clamp to secure it so it wouldn't fit loose like the ones you all use. I found a parts store that can order them for 20 some dollars forget the brand though, or a k&n, i went k&n because i prefer them, never had a problem with dirt getting in because i keep up with oiling it. and I never had a problem with the filter falling off since its all secured. I prefer to call my filter the "kc filter" its the upgraded version
luvemhot
13
Jan 5, 2006 02:16 PM
maevans
26
Jan 2, 2006 01:21 PM
mech2161
Oct 8, 2005 02:20 PM
johnny8
23
Jun 19, 2005 12:30 PM
Robbgt
17
Jan 5, 2005 08:47 PM
